    Technical / Mechanical plans
    layout
    3 Posts 3 Posters 2.1k Views 3 Watching
      dammerel
      Hi all
      Is it possible to do Technical / Mechanical plans in layout
      complete with dimensions and hidden linetype (dashed) similar
      to autocad. What I would like to do is complete a design in sketchup
      and finish the plans in layout Andrew
      • jujuJ Offline
        juju
        It could be possible. Thing is you'd probably want to pull all your teeth in one go without anaesthesia before doing it. LO is a RAM hog and slow, painfully so.
          seanheadrick
          Andrew,
          Todd Burch has a ruby script that does dashed lines if thats what your after. I think its on Smustard
          DO OR DO NOT, THERE IS NO TRY.
