    Two Face 'material'
    8 Posts 6 Posters 1.2k Views 6 Watching
    • C
      cornel
      Is there any script which allows to direct apply a "material" (color or texture) to both faces of a surface?!
      Anticipated thanks!
      Cornel
      • soloS
        solo
        That could be a handy script actually, especially for those that render their models.
        http://www.solos-art.com
        • K
          kwistenbiebel
          +1
          I am getting tendinitis from triple clicking geometry and rotating the view to assign mats to both front as back side of faces.
          • M
            Matt666
            Hi !
            Here is a quick script based on TIG "global material change".
            Adds "texturise selection" to the plugins menu.
            Applies a double-sided material.
            If you want to add a material to the script list, right-click on the desire material in the material SU window and choose "add to the model".
            seltxt.rb
            Frenglish at its best !
            My scripts
            • M
              marcosrodrigues
              Very useful. Merci, Matthieu!
              | menos é mais
              • C
                cornel
                Many thanks Matt!
                Your script is in a proper conjugation w/ that “material change”.
                Perhaps SU 7 will insert a check-box or a toggle button in ‘Materials’ dialog-box, to give as the possibility to direct apply a Two Face material, having the same origin, scale, orientation…, for both sides !?
                Cornel
                • R
                  RickW
                  Would it be easier to have an observer that automatically adds to the opposite face as you paint a face? Naturally, it could be turned on/off.
                  RickW
                  www.smustard.com
                  • M
                    Matt666
                    Observers.... I've never used these tools... I will try 😄
                    Thank you Rick !
                    My scripts
