    Two Face 'material'
    8 Posts 6 Posters 1.2k Views 6 Watching
      cornel
      Is there any script which allows to direct apply a "material" (color or texture) to both faces of a surface?!
      Anticipated thanks!
      Cornel
      • soloS Offline
        That could be a handy script actually, especially for those that render their models.
          kwistenbiebel
          +1
          I am getting tendinitis from triple clicking geometry and rotating the view to assign mats to both front as back side of faces.
            Matt666
            Hi !
            Here is a quick script based on TIG "global material change".
            Adds "texturise selection" to the plugins menu.
            Applies a double-sided material.
            If you want to add a material to the script list, right-click on the desire material in the material SU window and choose "add to the model".
            seltxt.rb
            Frenglish at its best !
            My scripts
              marcosrodrigues
              Very useful. Merci, Matthieu!
              | menos é mais
                cornel
                Many thanks Matt!
                Your script is in a proper conjugation w/ that “material change”.
                Perhaps SU 7 will insert a check-box or a toggle button in ‘Materials’ dialog-box, to give as the possibility to direct apply a Two Face material, having the same origin, scale, orientation…, for both sides !?
                Cornel
                  RickW
                  Would it be easier to have an observer that automatically adds to the opposite face as you paint a face? Naturally, it could be turned on/off.
                  RickW
                  [www.smustard.com](http://www.smustard.com)
                    Matt666
                    Observers.... I've never used these tools... I will try 😄
                    Thank you Rick !
                    My scripts
