    Problem with windowizer script
    4 Posts 3 Posters 784 Views 3 Watching
      acoffma
      hey im kinda new to the forum but ive been on su podium for some time now. recently i found the windowizer script and it is amazing, ive been trying to find a way to replicate the lattice modifier in 3ds max. one problem ive encountered though is that when i use the script and input all the dimensions it creates the window structure but the front face got deleted. see the picture below. im not sure if anyone else has had this problem but any help would be great. thanks
        RickW's Windowizer only makes the fronts - I think he's working on the next version that'll do the backs ?
        My Lattice-zer script is similar but only works on a single group with co-planar faces and edges that define the rail centres. It does make fully faced franes with ot without panes...
          acoffma
          k well i can deal with that theres way around it. i did however discover another problem i cant seem to solve. ive mainly been using the windowizer to create these organic curtain wall structures. i was just experimenting with the draw on face script and found out that if the face gets edited at all it will not "windowize". i used the smoove tool to create an organic plane and ran the windowizer, it create the structure with no problem. but when i drew on the circles and ran it it gave me this. the latticizer does work good for coplanar faces but i need something that can work for non coplanar
            RickW
            I'd like to see a smaller sample model that causes this problem. You can either PM me or contact me through http://www.smustard.com and I'd be happy to look at this.
            Thanks,
            RickW
            [www.smustard.com](http://www.smustard.com)
