    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 185.4k Views 108 Watching
      danielito
      @fletch said:
      Final proof of concept video (xvid-550kb) - just to let you know I think it's looking good. Thank you, Morisdov for your responsiveness - It's a great animation plugin and we will continue to promote it via Twilight. 👍
      wich application did you use?
      It looks great and its not a big file.
      I have designed a large house.
      Now I want to make an animation to show how it looks inside the house.
      When I make an animation with schetup creates a huge avi file of 600 mb and the animation is only 40 sec.
      Now I wonder if there is another program where I can make animation and the film is not larger than 5 mb and good quality.
      My email danielito12345@gmail.com
      sweden
      Is it 3d studio max or what?
      Sincerely,
      Daniel
        morisdov
        Hello Flecht and Ladies and Gentleman,
        download latest version 1.08 beta - with easing support, from -
        http://sites.google.com/site/morisdov/
        Please experiment and provide feedback if you find bugs.
          morisdov
          @gzekko said:
          repeating step - context menu add position x - when reopening saved models
          the very latest 1.08 beta download from my site (17/11/2010) will 'load' the number of positions for the context menu - on models created/extended using the latest 1.08 version.
          to insert a new position anywhere between two old positions
          1. add a new animation position as a new last position
          2. open the 'Animation Attributes Map'
          3. 'Move Left' the latest last position in between the two old positions
          Cheers, moris
          • MALAISEM Offline
            MALAISE
            Thanks a lot for the improvements. Sorry, but I'm quite busy and not enough time
            to try it deeper. 👍 👍
            MALAISE
            • F Offline
              Fletch
              Fantastic! 😲 I love that clicking on the little "A" in that dialog animates each and every thing individually. 😄 👍
              Fletch
              Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
              • charly2008C Offline
                charly2008
                Hi to All,
                When I came across this thread it occurred to me, to export a Sketchup animation to Kerkythea. But as so often, it did not work for now. Is there anyone here in the forum who has an animation rendered in Kerkythea or has experience with this workflow?
                I have the following problem: I created three simple scenes with a rotating cube. If I export them with SU2KT either as scenes or as an animation the workspace remains blank in Kerkythea. I tried too to load the exported script file (.kst) but the result was the same.
                I would love it if someone would help me, because I do not know what I'm doing wrong.
                Charly
                Untitled.skp
                  charly2008
                  Before i was loading the wrong script. When i loaded the correct script it tooks about 1 and 1/2 hour to render. Below the result no animation!
                  Charly
                    tomasz
                    Excellent update Morris!
                    I do like Fletch's animation 😄
                    Charly
                    I don't want to hijack the thread so please join the Kerkythea thread or PM me with questions.
                    The important things:
                    • enable Proper Animation observers
                    • export animation using: Full model per frame
                      Your animation will be stored in the export folder as jpgs. Use VirtualDub or similar software to build an animation file from them.
                    ... now .. where is that animation feature in SU2Thea ... 😄
                    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                      danbig
                      Hi Morisdov -
                      Thank you for the incredible tool.
                      Is there any limit on the number of positions that can be set?
                        danbig
                        Also -
                        How does the linking of positions and scenes work if you rename your scenes?
                        Does the Position 3 always link to the third scene that was created?
                          akobunge
                          hi to all.. i used this plugin. but once i save the animation in video file.. i cannot see the object move..please help...
                            rachmatrf
                            Thank you for this valuable tool...
                              rickymon
                              I solved the proper animation export issue by using another free RB plugin:
                              SmoothStepAnim.rb (Smooth Step Animation)
                              This plugin has its own export window and it recognizes all Properanimation modifications
                              AND it helps you to get smooth scenes transitions just in case u dont like the native scenes transitions from SU.
                              utube test here
                              http://www.youtube.com/watch?v=UL6tnTvphAE
                              Regards
                              Note: U can always use Twilight too...!
                              Images compiled using Sony Vegas 8
                              • F Offline
                                Funerall
                                Twilight does fine with animated scenes. I'm using it too. After rendering images, than I combine them with VirtualDub. Works great but takes long 😄
                                But I have some problems with Proper Animation 1.08B. I'm doing everything as I should (I think), but while moving objects with scenes, linear objects become unlinear 😄 I mean some part of the object disappears and then returns back. While rendering the same thing happens. Will there be any final version of 1.08B or a new version?
                                Thanks again for the wonderful plug-in Morisdov...
                                • ashscottA Offline
                                  ashscott
                                  Can anyone explain why the traditional exporter won't recognize the proper animation moving objects?
                                  I'm having to export through twilight as smoothstep forces me to cut out small pauses in the animation that need to be there. However, leaving my machine for 8 hours to render an animation only to come back and find that something has been mis-interpreted or I haven't set up properly is a bit of a pain.
                                  Just some stuff I do with Sketchup.
                                    Jim
                                    Exporting the object animations is just not something SketchUp does natively.
                                    You could try the Key Frame plugin - it currently costs $19 but has a 10-day trial. It can export the animation to Scenes which can them be exported using SketchUp's built-in export options, or allow anyone to view the animation in SketchUp.
                                    Regular Polygon
                                    Ruby Plugins for SketchUp
                                    (regularpolygon.blogspot.com)
                                    • ashscottA Offline
                                      ashscott
                                      Ok, but will that give a 'clean' export of animated objects to an AVI? Sounds like it just gives me scenes....within which SU's exporter still wont recognize animated objects.....
                                      Thanks for the reponse
                                      • ashscottA Offline
                                        ashscott
                                        I get the gist of your keyframe tool now, very clever, currently exporting the animation, will give an update.
                                        I'm surprised there isn't a simple ruby exporter based (perhaps) on add_frame_change_observer that would allow you to export an image stream of exactly what is seen in SU......Google Earth has this kind of functionality; in fact it appears to be the most robust hi res export option in Google Earth.....
                                        Excuse me if this is a poor suggestion as I don't understand ruby well.
                                        • ashscottA Offline
                                          ashscott
                                          So if I am going to use keyframes animation the whole animation needs to be done with the plugin.....
                                          It looks like a nice bit of gear but I have three models in sequence which will be edited together to make a movie and all the models have been prepared with proper_animation.rb
                                          Looks like I will have to use fraps (high res screen capture) for this one.
                                          Thanks for your help.
                                          • ashscottA Offline
                                            ashscott
                                            Anyone else noticed that object transitions cease to work after 25 scenes?
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
