    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 201.8k Views 108 Watching
    • FletchF Offline
      Fletch
      Thanks Rich. 😉
      One small issue now: Must Stop and Start Observer after any change to positions, or adding a scene. Or I have to save and close the file, and re-open it to see the changes made. It seems like it 'updated' itself better before.
      But now the scene transitions appear to be much smoother because it appears to cause the animation to occur for the entire transition time at .3 easing setting (and this is customizable). Thank you!
      Why ".3"? 😕
      Fletch
      • FletchF Offline
        Fletch
        Final proof of concept video (xvid-550kb) - just to let you know I think it's looking good. Thank you, Morisdov for your responsiveness - It's a great animation plugin and we will continue to promote it via Twilight. 👍
        Fletch
          GZekko
          morisdov,
          Thank you so much for such a great plugin! I was going ask about the animation speed issue, but then I find that there's an update with animation easing adjustment, and everything is wonderful!
          Don't know if it's a bug necessarily, but the only odd thing I've found while using Proper Animation is when I open a file with >7 animation positions, I have to right click an item, choose "add position 8, 9, etc" in order for them to show on the Animation Easing dialogue box. Otherwise, the dialogue box stops at position 7.
          Such an easy thing, but I bring it up in the interest of trying to help develop an even more user-friendly product.
          Thank you again!
          EDIT: Seems once I've done what I outlined above and save the file, I don't have to do it again, so it must have been due to working with a previously made file (using Proper Animation 1.07) with the new version. Just had to let the easing menu know that there are other steps, or something like that.
          • FletchF Offline
            Fletch
            @danielito,
            I use SketchUp with Proper Animation for animation of the building.
            I render the whole sequence in Twilight Render.
            It renders a still image in .jpg format (or whichever format I choose) for each frame of the animation.
            Then I open the sequence of images in Virtual Dub.
            I set up the audio and apply xvid compression, then save from Virtual Dub as .avi. There's only one compression I have found that is better than xvid, but I don't have it installed yet in Virtual Dub, and xvid works great, and very very fast, while maintaining good quality. (your video must be in dimensions multiple of 4 if you wish to use xvid or some other great codecs) So when you render your animation, keep that in mind.
            @Morisdov,
            If I can be so bold as to have a wish... it would be to add a position anywhere, so if I have 7 positions filled, and want to add something in the beginning, I could add a position 1, and it would move current position 1 to be now 2, 2 to be 3, and so on... this would make editing the animation sequence much easier. It would be nice, along those lines, if you show it to a client and they ask for changes. So now they want something else to happen between position 4 and position 5, you could add a position in between them without replacing position 5 with something different.
            Hope this idea is clear. 😕 Sorry if it's a bad explanation.
            Fletch
              danielito
              wich application did you use?
              It looks great and its not a big file.
              I have designed a large house.
              Now I want to make an animation to show how it looks inside the house.
              When I make an animation with schetup creates a huge avi file of 600 mb and the animation is only 40 sec.
              Now I wonder if there is another program where I can make animation and the film is not larger than 5 mb and good quality.
              My email danielito12345@gmail.com
              sweden
              Is it 3d studio max or what?
              Sincerely,
              Daniel
                morisdov
                Hello Flecht and Ladies and Gentleman,
                download latest version 1.08 beta - with easing support, from -
                http://sites.google.com/site/morisdov/
                Please experiment and provide feedback if you find bugs.
                  morisdov
                  @gzekko said:
                  repeating step - context menu add position x - when reopening saved models
                  the very latest 1.08 beta download from my site (17/11/2010) will 'load' the number of positions for the context menu - on models created/extended using the latest 1.08 version.
                  to insert a new position anywhere between two old positions
                  1. add a new animation position as a new last position
                  2. open the 'Animation Attributes Map'
                  3. 'Move Left' the latest last position in between the two old positions
                  Cheers, moris
                  • MALAISEM Offline
                    MALAISE
                    Thanks a lot for the improvements. Sorry, but I'm quite busy and not enough time
                    to try it deeper. 👍 👍
                    MALAISE
                    • FletchF Offline
                      Fletch
                      Fantastic! 😲 I love that clicking on the little "A" in that dialog animates each and every thing individually. 😄 👍
                      Fletch
                      • charly2008C Offline
                        charly2008
                        Hi to All,
                        When I came across this thread it occurred to me, to export a Sketchup animation to Kerkythea. But as so often, it did not work for now. Is there anyone here in the forum who has an animation rendered in Kerkythea or has experience with this workflow?
                        I have the following problem: I created three simple scenes with a rotating cube. If I export them with SU2KT either as scenes or as an animation the workspace remains blank in Kerkythea. I tried too to load the exported script file (.kst) but the result was the same.
                        I would love it if someone would help me, because I do not know what I'm doing wrong.
                        Charly
                        Untitled.skp
                          charly2008
                          Before i was loading the wrong script. When i loaded the correct script it tooks about 1 and 1/2 hour to render. Below the result no animation!
                          Charly
                            tomasz
                            Excellent update Morris!
                            I do like Fletch's animation 😄
                            Charly
                            I don't want to hijack the thread so please join the Kerkythea thread or PM me with questions.
                            The important things:
                            • enable Proper Animation observers
                            • export animation using: Full model per frame
                              Your animation will be stored in the export folder as jpgs. Use VirtualDub or similar software to build an animation file from them.
                            ... now .. where is that animation feature in SU2Thea ... 😄
                              danbig
                              Hi Morisdov -
                              Thank you for the incredible tool.
                              Is there any limit on the number of positions that can be set?
                                danbig
                                Also -
                                How does the linking of positions and scenes work if you rename your scenes?
                                Does the Position 3 always link to the third scene that was created?
                                  akobunge
                                  hi to all.. i used this plugin. but once i save the animation in video file.. i cannot see the object move..please help...
                                    rachmatrf
                                    Thank you for this valuable tool...
                                      rickymon
                                      I solved the proper animation export issue by using another free RB plugin:
                                      SmoothStepAnim.rb (Smooth Step Animation)
                                      This plugin has its own export window and it recognizes all Properanimation modifications
                                      AND it helps you to get smooth scenes transitions just in case u dont like the native scenes transitions from SU.
                                      utube test here
                                      http://www.youtube.com/watch?v=UL6tnTvphAE
                                      Regards
                                      Note: U can always use Twilight too...!
                                      Images compiled using Sony Vegas 8
                                      • F Offline
                                        Funerall
                                        Twilight does fine with animated scenes. I'm using it too. After rendering images, than I combine them with VirtualDub. Works great but takes long 😄
                                        But I have some problems with Proper Animation 1.08B. I'm doing everything as I should (I think), but while moving objects with scenes, linear objects become unlinear 😄 I mean some part of the object disappears and then returns back. While rendering the same thing happens. Will there be any final version of 1.08B or a new version?
                                        Thanks again for the wonderful plug-in Morisdov...
                                        • ashscottA Offline
                                          ashscott
                                          Can anyone explain why the traditional exporter won't recognize the proper animation moving objects?
                                          I'm having to export through twilight as smoothstep forces me to cut out small pauses in the animation that need to be there. However, leaving my machine for 8 hours to render an animation only to come back and find that something has been mis-interpreted or I haven't set up properly is a bit of a pain.
                                          Just some stuff I do with Sketchup.
                                            Jim
                                            Exporting the object animations is just not something SketchUp does natively.
                                            You could try the Key Frame plugin - it currently costs $19 but has a 10-day trial. It can export the animation to Scenes which can them be exported using SketchUp's built-in export options, or allow anyone to view the animation in SketchUp.
                                            Regular Polygon
                                            Ruby Plugins for SketchUp
                                            (regularpolygon.blogspot.com)
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
