    Glass Lighting Shades
    extensions
    3 Posts 2 Posters 1.2k Views 2 Watching
    • B
      bytor
      Hello,
      I am trying to figure out the best way to represent Glass Lighting Shades. Inthe attached image - I have used a material from the "Illuminants" library. I also have spot lights inside to present the most accurate dispersion of the light. I like how the shades add to the general illumination, and help to take the edge off of the spotlight shadows, but I think they "glow" a little too much to be realistic. What setting do I need to work with to control this?
      Thanks,
      Bytor
      Find the Cost of Freedom.....
      • FrederikF
        Frederik
        Hi Bytor,
        I'd say that it's the refraction you need to adjust/work with... πŸ˜‰
        Also - have you looked and downloaded the Transluscent materials where you'll find a layred material named "Plastic transluscent (useful for modern lamps)", which I assume is a material close to what you're looking for... πŸ˜‰
        Oohhh... And btw... Your render seem to come along nicely... πŸ˜‰
        Looking forward to see the end result... πŸ˜„
        Cheers
        Kim Frederik
        • B
          bytor
          Thanks Fredrik!
          The translucent material were just what I was looking for - don't know how I missed them before. I used those materials for the shades and just replaced the spotlights with a face and the illuminat material mapped to them - very easy to control. Here is an update with those changes - I still have a little more tweaking I want to do.
          Bytor
