    Help please! Stamp Tool causes crash!
    3 Posts 3 Posters 2.3k Views 3 Watching
    • H Offline
      hoangduong
      i'm trying to use the stamp tool to place a building foot print on terrain but it crashes everytime.
      i would select the stamp and as soon as i pick the footprint, sketchup crashes.
      i'm using sketchup 6.4 or the most recent update. this has never happened before.
      is there a way to repair sandbox or something? or do i need to un-install and then re-install all of sketchup?
      thanks.
      • Chris FullmerC Offline
        Hello, is there any chance you could post the model to the forum so we can take a look? I've had problems with the drape craqshing SU, but rarely (if ever?) the stamp tool. I'd like to look at it,
        Chris
        All my Plugins I've written
        • P Offline
          Panga
          Hi Hoangduong,
          I'm frequently confronted to this problem when I use the stamp tool.
          For me, it happens when i have other objects near the surface I want to stamp and when my model become too large.
          To avoid this, there's a few solutions :
          1. Try to put all others objects in a turned off layer
          2. Take your surface and your building print out of your model, and do the stamp in a new file, and then copy it in your model (not always possible...)
          3. If you have an old version of Sketchup 5, save your file in the SU 5 format, do it under SU 5, and reopen it with SU6. It never crash on sketchup 5 for me.
          Hope it helps you.
