    Hardware recommendations
    409 Posts 97 Posters 81.1k Views 97 Watching
      remus
      That does sound pretty killer chango, i can only dream of such machines 😄
      Only thing i would suggest is perhaps try to get some more memory, as if you plan on doing any renders (reasonably likely on an architecture course, i wouldve thought) they can really start to eat up the memory in larger sizes. Possibly worth getting a bigger HDD as well, youd be surprised how quickly you can use up 300gb.
        chango70
        My past experices of using Vray to do renderings is that actually the Ram requirement isn't high, sort of hovering around 2GB utilisation while the 2 cores were working flat out. Is that because 2 core can only use 2 GB? Has anyone done really heavy textured renderings?
        Thanks for the suggestion Remus, Ram is so cheap these days I might as well get 8GB.
          remus
          I dont really know much about vray, although in indigo its certainly very easy to run out of memory on large renders.
          Either way having more RAM isnt going to hurt.
          • plot-parisP Offline
            plot-paris
            I experienced, that the ram is especially necessary, when doing renderings with high resolution.
            I processed a scene recently, which contained more than one billion polygons. the ram used by indigo was mere 70 MB, because my resolution was only 800 x 600.
            when I tried to render the same scene with a proper resolution, my computer ran out of memory...
            • K Offline
              kwistenbiebel
              As for using render engines in a SU combo, RAM plays a very important role.
              Luckily, Skindigo launches Indigo as a separate process from SU, which enables the possibility to use more than 3.5 GB of RAM (if you run a 64bit OS).Same goes for Maxwell.
              Some of the other render engines however (Podium, Vray, etc..) share the same process as Sketchup.
              And since Sketchup is 'Not Large Adress Aware' and does not support 64 bit (a limit of 3.5 Gb Ram)or multi cores,it's easy to run short of RAM. It doesn't matter if your PC has 8 Gb or even 16 Gb. Every Gb over the 3.5 Gb limit will not be used. (actually the limit is even smaller, as the operating system claims a large chunck from that 3.5 Gb for hardware reasons)
              Sketchup actually handicaps render engines like Vray...A pitty, really. 😢
                dsarchs
                Kwistenbiebel --
                I've been looking into 64-bit architecture lately to see if it's worth it or not.
                Are you saying that if you are using 64-bit OS emulating a 32-bit software application [SU] that even though you are limited to ~3.5 GB RAM that this is only for each program?
                For example, each active program could use up to ~3.5 GB RAM? If so this would make it useful to have very large amounts of RAM [for multi-tasking] even if the software individually does not support more.
                Knowledge is a polite word for dead but not buried imagination.
                -e.e.cummings
                • K Offline
                  kwistenbiebel
                  I believe it works like that yes.
                  (someone correct me if I am wrong).
                  • Chris FullmerC Offline
                    That was my understanding too. Though I thought I read in another unrelated thread that it is possible for a software to enable large memory handling (over the 3-4gb barrier) if it is only 32 bit software running on a 64 bit OS.
                    I whish I knew more about all this. I did upgrade my comp to Vista 64 bit with 8gb ram. Its nice and I can run lots of stuff at the same time without a hitch. I can be doing detailed renders in 3dsmax and still work hard in photoshop and sketchup. Its really nice 😄
                    Chris
                    All my Plugins I've written
                    • W Offline
                      wyatt
                      Hey everyone. I've read this thread with great interest. I ran several tests over the weekend with the City model. Now I need someone to tell me if these results are good and how to improve them.
                      Specs: Windows XP SP2, Pentium 4 CPU, 3.6GHz, 2GB RAM latency 2 (see note below), 512 MB NVIDEA GeForce 8600, HA & FF on, 4x AA
                      (Frame Rates averaged over 3 trials)
                      Scene 1: 45.6 fps
                      Scene 2: 49.6 fps (I think it's interesting that this scene displayed faster than #1.)
                      Scene 3: 27.9 fps
                      Scene 4: 10.4 fps
                      Scene 5: 1.4 fps (52 seconds)
                      Scene 6: 0.5 fps (134.1 seconds)
                      Scene 7: 0.2 fps (350.2 seconds)
                      With AA turned off, the results were virtually identical, except 1- and 3-seconds slower on Scenes 6 & 7.
                      I ran more tests with an additional 1 gig of 3-latency RAM (which somehow totalled to 2.69Gb...thought that was strange) and processing speed of the model was actually a bit slower even though my total RAM was more (ie Scene 1: 44.9 fps vs 45.6). I guess the different latencies dumb themselves down to the slowest RAM. Can anyone confirm this?
                      Subjectively, I'm not impressed by my computer's performance. But maybe I did better on the benchmark test than I think I did. Regardless, I'm not sure what changes would improve performance the most: processor, RAM, or graphics card. Adding RAM is easy enough. I'm discussing with others in my office the possibility of swapping my GeForce 8600 graphics card for a 512 MB Quaddro FX 1700, but I don't want to do that if it won't help. I use SU, Photoshop, and AutoCAD, often simultaneously. I don't use other rendering engines at the moment. Any advice?
                      Thanks!
                      Wyatt
                      • soloS Offline
                        solo
                        Regarding the RAM thing, yes your machine is only as fast as the slowest RAM module.
                        http://www.solos-art.com
                          chango70
                          Thanks for the interesting information guys. I think i'll get 8Gb of Ram now. Indigo sounds like a good renderer to try. I like Vray because its is really fast. I've been doing relatively small sized renderings thats why they didn't impact on my Ram noticeably. 😳
                          Since I am gonna be using Rhino as well I think I'll stick to the Quadro FX Card, however the new GTX 200 series has ludicrous amount of bandwidth! Don't know if anyone has had experience with FireGL cards form ATI?
                          I heard that in Q3 Intel is due to release several new processors which would mean the Q9550 would most like drop in price. I think its a good processor with good OC headroom. Which brings me to the question. Does anyone have experience with OCed (Overclocked) systems and performance in Sketchup?
                            remus
                            I havent got any personal experience with overclocking and SU, but on a theoretical level it should work pretty well, as all your doing is increasing the clock speed of the CPU, and as SU cant take advantage of lots of cores, its pretty beneficial to have each one running fast so SU can take advantage of the individual speed.
                              plot-paris
                              I just did the city- and the cube-test with my brand new laptop ( 😍 )
                              (Intel Core 2 Duo 2.5Ghz, 4GB Ram, Nvidia GeForce 9650 with 512Ram,)
                              and interestingly I discovered, that the screen resolution does NOT change the framerate at all!
                              scene7 of the city test took:
                              216 Secondswith a resolution of 1980 x 1050pixels
                              and
                              215 Secondswith a resolution of 800 x 600pixels
                              can anybody explain to me, why that is? may it be, because all the SketchUp geometry (inclusive of shadows?) is vector-based and therefore doesn't affect the resolution at all? does that mean in reverse mean, that you can run a screen with a resolution as high as you like (that is supported by your graphic card) without losing any framerate? 😒
                                chango70
                                That doesn't make any sense. Surely higher screen resolutions mean more pixels to update for the graphics card!!!
                                  remus
                                  That means its probably something the CPU deals with that is slowing SU down, although i cant remeber which bits of the model the cpu deals with 😛
                                  • brodieB Offline
                                    brodie
                                    Regarding the screen resolution, the same has held true for me as well. I have 2 monitors. One is set to 1600x1200 I think and the other is 1280x1040ish. I ran the test on both and got the same results. I didn't even mention it because I thought maybe I was crazy for assuming their should be a difference.
                                    Conclusion: SU is wierd and defies the laws (sketchy) physics.
                                    -Brodie
                                    • K Offline
                                      kevsterman
                                      I've read this thread with interest but being a computer dunce I have no idea what all these technicalites mean 😕
                                      I want to buy myself a really good computer in the next couple of weeks as I'm hoping to be doing a lot more SU work and rendering in the future and want a machine that is going to keep up with the demand.
                                      Has anyone summarized all this data yet and come up with the definitive spec?
                                      Or could someone advise on the very best computer to get?
                                      I've bought about 4 computers in the past and always end up with ones that are slow 😞 . I don't want to make the same mistake this time around. My bank balance won't allow it.
                                      "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                        remus
                                        If your looking for a beefy render machine you'll want to go for a quad core or more. You'll also want to get as much RAM as you can afford, id suggest about 16 GB. You'll also need a 64 bit operating system to go with this.
                                        The really tricky bit is graphics cards as these are the things that can mess around with SU if you dont go for the right one. I can noyl vouch for the nvidia 7800 as thats what ive got. Its worth checking out this survey to see what everyone else has got and what seems to work for everyone.
                                        Apart form that everything else is pretty much down to how much you want to spend.
                                        this is probably a good starting point: http://www1.euro.dell.com/content/products/productdetails.aspx?c=uk&cs=ukbsdt1&id=precn_t7400&l=en&s=bsd
                                          C'mon, Remus, don't tease me! I quickly put together a not even top machine for the price of 6,223 GBP (VAT not included) 😲
                                            remus
                                            A positive bargain! i put together one for 12, 600 GBP 😄
                                            • 6
                                            • 7
                                            • 20
                                            • 21
                                            • 5 / 21
