    Creating a ball
    6 Posts 5 Posters 1.4k Views 5 Watching
      J. D. Champion
      Hello everyone,
      I need some help to create a ball.
      Also, I am trying to make people. I probably could do most of it, I just have a problem creating a ball (head, and hair).
      Does anyone have any idea.
      Thanks!
      John D. Champion
      • jujuJ Offline
        juju
        Firstly: create a base shape, see image 01 below.
        Secondly: use Subdivide and Smooth on the base shape, two iterations should do nicely, see image 02.
        Thirdly: et voila! See image 03.
        After the above you could use Joint Push Pull (JPP) or the scale tool to get it to the size you want.
        • ely862meE Offline
          ely862me
          or if u have sub smooth just make a cube and use 2 or 3 itinerations
          Elisei (sketchupper)
          Come and See EliseiDesign
          • soloS Offline
            solo
            Can you not use the standard sphere shape that comes with SU in the component library under the 'shapes' subfolder?
            http://www.solos-art.com
            • ely862meE Offline
              ely862me
              if u want a ball go to window/components/shapes and take the sphere from there
              or if u want to create it,see this
              [flash=425,344:2g628w8a]http://www.youtube.com/v/DBEzRkTcdFQ&hl=en[/flash:2g628w8a]
                dylan
                There are many ways to create spheres these days as already demonstrated, but as solo mentions above, why not keep things simple and quick and use the ones which are provided for you in Components/Shapes.
                http://dmdarchitecture.co.uk/
