Creating a ball
Hello everyone,
I need some help to create a ball.
Also, I am trying to make people. I probably could do most of it, I just have a problem creating a ball (head, and hair).
Does anyone have any idea.
Thanks! -
Firstly: create a base shape, see image 01 below.
Secondly: use Subdivide and Smooth on the base shape, two iterations should do nicely, see image 02.
Thirdly: et voila! See image 03.
After the above you could use Joint Push Pull (JPP) or the scale tool to get it to the size you want.
or if u have sub smooth just make a cube and use 2 or 3 itinerations
Can you not use the standard sphere shape that comes with SU in the component library under the 'shapes' subfolder?
if u want a ball go to window/components/shapes and take the sphere from there
or if u want to create it,see this
[flash=425,344:2g628w8a]http://www.youtube.com/v/DBEzRkTcdFQ&hl=en[/flash:2g628w8a]
There are many ways to create spheres these days as already demonstrated, but as solo mentions above, why not keep things simple and quick and use the ones which are provided for you in Components/Shapes.
