    Dovetail puzzle
    9 Posts 7 Posters 5.1k Views 7 Watching
    • G Offline
      Gidon Yuval
      I came across a nice little puzzle that I thought I'd share. A woodworker friend handed me two blocks of wood (each from a different wood, for contrast) joined together with what appeared to be an impossible dovetail joint.
      I just had to model it to show you guys.
      This is what it looks like assembled. There's no way to have a dovetail joint on all four sides. There'd be no way of assembling it.
      Or would there...?
      Now have a look at the model... πŸ˜‰
      Dovetail puzzle.skp
      If you don't know where you're going, you're never going to get there.
        Here the image of Skp πŸ’š
        There is no trap in the pieces! β˜€
          Here the Skp !
          Of course it will more easy to build it in reality for find the only good solution! πŸ˜’
          Have fun 😎
          PS It is also not so easy to unbuild it πŸ’š
          puzzle.skp
            todd burch
            [attachment=1:3f2kxbjv]<!-- ia1 -->Dovetail puzzle.jpg<!-- ia1 -->[/attachment:3f2kxbjv]
            Or would there...?
            [attachment=0:3f2kxbjv]<!-- ia0 -->Dovetail puzzle.skp<!-- ia0 -->[/attachment:3f2kxbjv]
            ha ha ha!! I know this joint. I could make one, no problem!
            Todd
              Hehe
              Solution is given by the X-ray πŸ˜„
              Very cool trick! 😲
              Do you now this one? πŸ˜‰
              I don't give you the solution because it's one of the more "simple" crazzy headache I had never seen πŸ˜†
              Even you find a 3D solution(many exist), that don't say that you can assembly it in reality!
              Only one works! πŸ˜‰
                sketchy
                nice, thanks for posting this.
                  tomsdesk
                  Gidon, very cool...I've sent on to a couple of others, thanks!
                  2.5D Trees & Shrubs!
                    remus
                    A pretty nifty trick, certainly had me stumped.
                      SchreiberBike
                      Had me stumped until I saw the inside, then it was obvious. That's the best kind of trick.
                      Some planes are made with double dovetails between the side and the sole. I think it's done by pounding metal around corners. Can't do that with wood. Here's a pic I found on the net.
                      http://www.allwoodwork.com/article/articleimages/plane1.jpg
