    Line colours
    6 Posts 3 Posters 1.3k Views 3 Watching
    • T
      the2ems
      Is it possible to change the colours of individual lines?
      • GaieusG
        Yes. Go to your styles dropdown dialogue, > In model > Edit > Edge settings and there you can change the display mode from all same to colur by material.
        Now you can paint your lines (only with colours of course, not textures).
        • T
          the2ems
          Not having any success 😳 Do I have to set different materials for each line?
          • R
            remus
            Shouldnt have to set material for each line.
            If you switch to wireframe mode it can make it a lot easier to paint the edges. Also, if oyu want to paint a few vertices the same colour select them all before you start, they should thne all be painted the same colour after 1 paint. Speeds thigns up a lot πŸ‘
            • GaieusG
              You can paint them with the paint bucket tool with any colour you want. It's just hard to "aim" at a one pixel wide line. Select the (even a whole bunch) first and then use the paint tool.
              Have you done the settings I told above?
              • T
                the2ems
                Sorted, thanks. πŸ‘
