    Line colours
    6 Posts 3 Posters 1.1k Views 3 Watching
      the2ems
      Is it possible to change the colours of individual lines?
        Yes. Go to your styles dropdown dialogue, > In model > Edit > Edge settings and there you can change the display mode from all same to colur by material.
        Now you can paint your lines (only with colours of course, not textures).
          the2ems
          Not having any success 😳 Do I have to set different materials for each line?
            remus
            Shouldnt have to set material for each line.
            If you switch to wireframe mode it can make it a lot easier to paint the edges. Also, if oyu want to paint a few vertices the same colour select them all before you start, they should thne all be painted the same colour after 1 paint. Speeds thigns up a lot πŸ‘
              You can paint them with the paint bucket tool with any colour you want. It's just hard to "aim" at a one pixel wide line. Select the (even a whole bunch) first and then use the paint tool.
              Have you done the settings I told above?
                the2ems
                Sorted, thanks. πŸ‘
