    Texture on round surface
    5 Posts 3 Posters 835 Views 3 Watching
      twharvey
      I'm working on a collection of Pre-Columbian tera cotas. The first one is a Guatamalan/Mayan bowl, photo below. When I try to paint the texture onto the outside of the bowl I get the result shown in the second shot below. I tried following one of Pete's old tuts on painting a map on a globe. But something is wrong: streaky sides.
      Thanks in advance,
      Tom
      Tom
      • jujuJ Offline
        juju
        I'd say make a quarter of the bowl, texture that, make it a component, rotate copy 3 more times to complete the bowl. You'll have to toy a little with the texture to get it to "tile" or you could play with the texture in PS.
          twharvey
          Thanks, JuJu,
          I'll try that. I was hoping to avoid a solution like that because the bowl isn't uniform. But, I guess, sometimes art is best served by compromise.
          Tom
          Tom
            twharvey
            I tried that and it worked pretty well. Thanks again, JuJU,
            Tom
            Tom
              remus
              You could also try turning on hidden geometry and then painting the faces with the same texture, but rotated around. This would keep the irregular geometry of the bowl, as well.
