    FREAK Sketchup Error
    5 Posts 5 Posters 1.0k Views 5 Watching
    • E Offline
      ELYSIUM
      Hi all,
      I was working on a project in the office, doing some facades when after a couple of zooms in and out this happned to the model! It's really weird! has anyone had this one before? it looks
      like it has extendend the facade to another place. what do you think?
        remus
        I dont suppose you accidentally moved some geometry? ike you said, it looks like its moved half of the geometry somewhere else. Perhaps just another mystery?
          That's the aliens, Pedro! You have found a wormhole to a black hole and it is just sucking your model in. Be careful, your screen is next then your desktop, your house etc. 🤣
          Could you post the model?
            lewiswadsworth
            I have had it happen. Usually a Bugsplat will shortly follow. Even if it does not and you can recover or undo to the point before the error became apparent, go to Window menu>Model Info>Statistics>Fix Problems immediately. Usually some huge list of errors will show up.
            At one point, I found this happening a lot and found it was tied to a Ruby (since deleted, so I don't know if it is the current one of that name or not) for selecting all instances of a component at once. If the Ruby was used on a component while inside another component and when there were instances of the first component outside the current editing environment, bad things like this could happen.
            On the other hand, sometimes it just happens. Be sure to turn on hidden lines if you try to fix it...there tend to be odd ones, nearly infinitely long, floating around.
            col sporcar si trova
              tomsdesk
              Sorry to celebrate your frustration, Elysium...but: YEAH! I'M NOT INSANE!
              2.5D Trees & Shrubs!
