    Push/Pull Question
    5 Posts 4 Posters 824 Views 4 Watching
    • A
      ARCHI_BUM
      Probably a simple question: How come sometimes when i push/pull a face the original face disappears and i have to draw an edge to make it reappear, and other times the tool seemingly works properly with the original face staying visible after the command?
      Thanks.
      • J
        Jim
        Archi,
        It's one of those mysteries of life.
        If this happens, tap the Ctrl key while push-pulling, and the original face will be left there.
        • A
          ARCHI_BUM
          LOL!!
          Thanks Jim.
          • GaieusG
            Yes, I often wonder about this as well. And though Jim's suggestion works, it leaves a reversed face there only so a couple of extra clicks are needed.
            I think it depends on whether the face originally was to be an inside or outside face or being an ascendent of another face but I am always too lazy to invesigate this.
            • AnssiA
              Anssi
              I don't think there is consistency in this. It's the same with punching holes: Draw a face, pushpull it to some thickness, draw a grid (with Windowizer, for instance) and push-pull one grid face to make a hole. Now start double-clicking on the rest of the squares. Most often than not, some of them do not make a hole, but leave two z-fighting faces instead, or then at some stage the bottom face of the box disappears completely.
              Anssi
