    Gatehouse renders
    13 Posts 8 Posters 1.3k Views 8 Watching
    • EdsonE Offline
      Edson
      two attempts at rendering a gatehouse for a project i am doing. in one i used some sketchup trees whose leaves did not render. then i inserted a background in the second in photoshop.
      time of render in podium: 4min. + 10 min in photoshop for the first one and 15 for the second.
      i am glad i am making progress. slow and steady.
      http://www.mahfuz.arq.br
      • boofredlayB Offline
        boofredlay
        Great start!
        Why is your viewing angle so low to the ground? Makes me feel like I fell skateboarding or something.
        • Joe WoodJ Offline
          Joe Wood
          Edson, have you been working on the structural part of that gatehouse? If so do you have any construction views so we could see how it's built?
          Joe Wood
          woodsshop.com/
            remus
            Might want to try and find a better stone texture for the walls as well, its tiling quite badly πŸ˜‰
            Nice render though, i can see good things if you keep going with it.
            • marked001M Offline
              marked001
              ah.. i think i remember this project... i agree about the stone texture, but looks like a great start and i definitely love the design.
              http://www.revision21vis.com
              instagram: revi21on
              • EdsonE Offline
                Edson
                i thank you all for your comments.
                eric,
                i lowered it a bit trying to make a small building look more impressive. if it gives you that impression maybe the clients will feel that way too. i'd better make it a normal point of view.
                joe,
                yes i have. right now what i have is a tentative structure based on my not-so-extensive experience with wooden structures. later on i will submit it to some expert on the matter. if you like, i can send you a few pictures of it.
                remus,
                i had noticed the tiling problem. but, as i am learning, i am taking one step at a time. it was more important at this moment to get the lighting, the color of the texture and the bump right than fixing the tiling problem. later on i will get to that.
                • Joe WoodJ Offline
                  Joe Wood
                  I do like Edson, I'd very much like to see the structure and give some comments on it. I'm very interested in roofed entrys/gatehouses.
                  Joe Wood
                  woodsshop.com/
                  • EdsonE Offline
                    Edson
                    thanks, jason. you remember well. this is a project i have been working on for 3 years. they did not like a flat-roofed gatehouse so i designed this one.
                    as we had to spend a lot of time dealing with environmental licensing, the actual design was put on hold so the clients have not seen this yet (which is not such a bad thing since when i show it to them i will be able to use these renders).
                      tomsdesk
                      Edson, really nice! (thought this one would have been long done by now...so it often goes, huh?) I like the lowered viewpoint, but see Eric's point: how 'bout sitting-in-a-small-car viewpoint...a happy medium?
                      2.5D Trees & Shrubs!
                      • P Offline
                        perk
                        Edson
                        What did you use for the grass in the forground? I have been looking for good grass materials and components.
                        BTW nice renderings!
                        • DanielD Offline
                          Daniel
                          Looks great, Edson. In my pickiness, have two comments for what they're worth:
                          On the horizontal boards, you might want to shift the textures on some, maybe even rotate 180 degrees, so they don't look like clones.
                          Wouldn't that wood weather to a gray over time? It appears very orange on my computer.
                          My avatar is an anachronism.
                          • EdsonE Offline
                            Edson
                            @perk said:
                            Edson
                            i got it from the Podium site. i hope it is ok to give them to you.
                            grass.zip
                            • EdsonE Offline
                              Edson
                              i agree with with your comments. ideally i would have addressed those problems earlier but as i am a newbie at this i left some refinements to do later. my main goal at this point is to get the lighting right, then comes texturing.
