    Gatehouse renders
    13 Posts 8 Posters 1.4k Views 8 Watching
      remus
      Might want to try and find a better stone texture for the walls as well, its tiling quite badly πŸ˜‰
      Nice render though, i can see good things if you keep going with it.
      • marked001M Offline
        marked001
        ah.. i think i remember this project... i agree about the stone texture, but looks like a great start and i definitely love the design.
        http://www.revision21vis.com
        instagram: revi21on
        • EdsonE Offline
          Edson
          i thank you all for your comments.
          eric,
          i lowered it a bit trying to make a small building look more impressive. if it gives you that impression maybe the clients will feel that way too. i'd better make it a normal point of view.
          joe,
          yes i have. right now what i have is a tentative structure based on my not-so-extensive experience with wooden structures. later on i will submit it to some expert on the matter. if you like, i can send you a few pictures of it.
          remus,
          i had noticed the tiling problem. but, as i am learning, i am taking one step at a time. it was more important at this moment to get the lighting, the color of the texture and the bump right than fixing the tiling problem. later on i will get to that.
          http://www.mahfuz.arq.br
          • Joe WoodJ Offline
            Joe Wood
            I do like Edson, I'd very much like to see the structure and give some comments on it. I'm very interested in roofed entrys/gatehouses.
            Joe Wood
            woodsshop.com/
            • EdsonE Offline
              Edson
              thanks, jason. you remember well. this is a project i have been working on for 3 years. they did not like a flat-roofed gatehouse so i designed this one.
              as we had to spend a lot of time dealing with environmental licensing, the actual design was put on hold so the clients have not seen this yet (which is not such a bad thing since when i show it to them i will be able to use these renders).
                tomsdesk
                Edson, really nice! (thought this one would have been long done by now...so it often goes, huh?) I like the lowered viewpoint, but see Eric's point: how 'bout sitting-in-a-small-car viewpoint...a happy medium?
                2.5D Trees & Shrubs!
                  perk
                  Edson
                  What did you use for the grass in the forground? I have been looking for good grass materials and components.
                  BTW nice renderings!
                  • DanielD Offline
                    Daniel
                    Looks great, Edson. In my pickiness, have two comments for what they're worth:
                    On the horizontal boards, you might want to shift the textures on some, maybe even rotate 180 degrees, so they don't look like clones.
                    Wouldn't that wood weather to a gray over time? It appears very orange on my computer.
                    My avatar is an anachronism.
                    • EdsonE Offline
                      Edson
                      @perk said:
                      Edson
                      i got it from the Podium site. i hope it is ok to give them to you.
                      grass.zip
                      • EdsonE Offline
                        Edson
                        i agree with with your comments. ideally i would have addressed those problems earlier but as i am a newbie at this i left some refinements to do later. my main goal at this point is to get the lighting right, then comes texturing.
