Crashing
I've been having problems with SketchUp crashing quite frequently... It doesn't give any error messages, just plain quits..
I'm running it on a new MacBook Pro, 2.4 GHz Intel Core 2 Duo, 4GB 667 MHz DDR2 SDRAM... should be plenty of machine to support SketchUp without issues. any settings I need to change to improve stability?
On a Mac, any application that quits like that will write a log file to:
your_home_directory/Library/Logs/CrashReporter/Sketchup.crash.log
Adam
Have you ever tried to uninstall and clean all files dedicated to SU and reinstall? Also if you are not using the latest version, maybe updating helps. If you can not fix it, go on windows version.
Register LoginAdvertisement
