    Radial text
    6 Posts 4 Posters 1.4k Views 4 Watching
    • A
      angusog
      G'Day Folks and folkess's
      looking for a way to insert/ intersect radial text ( see Skp)
      atm i am using 3d text tool
      then i explode said text
      regroup each individual letter ( for ease of positioning)
      Move into position and rotate to desired angle
      intersect and delete unwanted geometry
      all in all a long convoluted process
      radial text.skp
      • V
        Voder Vocoder
        You'd be better off doing the fit text to curve operation in a 2D graphics program that has special features to do exactly that. CorelDraw, for instance, has a dandy text-on-a-curve function, with all kinds of controls.
        After you've got the outlines, you can import them into SU via dxf or dwg and then Push/Pull etc. to suit.
        ~Voder
        • A
          angusog
          Thanks Voder, I have adobe elements v3 will check that out see if i can do that, would actualy work perfectly if i can
          thanx again
          rob
          • T
            tim
            The free 'Inkscape' application does it quite well, too. In fact Inkscape is really rather a good application so long as you can ignore the rather unpleasant visual quality of the UI - on a Mac it has to run under the X Windows library and the UI look really jars with the nice clean OS X UI.
            But it is good and it is free. Hard to argue with that.
            • A
              angusog
              Thanks Tim will d/l that and give it a go
              • L
                lapx
                How about curving in the other direction? These should be on the wish list for function with the 3d tect commmand.
