    How to set the view in PDF
    extensions
    1 Posts 1 Posters 666 Views 1 Watching
    • Al HartA Offline
      Al Hart
      I am trialling your 3D PDF creator and am wondering is there any way to change the point of rotation? for example I want to be able to send the attached PDF to a client and have them take a close look at the connections at either end of the frame but this is very difficult if we can't move the rotation point to the end of the frame.
      You can create some view frames in SketchUp, and these will be carried into the 3D PDF.
      Otherwise, you could add some "dummy" geometry and see if it changes how the scene rotates.
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
