    How can I align perfectly layouts views?
    layout
    3 Posts 2 Posters 2.6k Views 2 Watching
    • G
      Gjenio
      I have created a couple of scenes(top, front and left views, with dimensions)of a model within SketchUp. When I put them into Layout I can't align that views exactly so that the front view is straight above to the top one and the left view at the same height of the front one.
      I attached a pdf to clarify what I try to explain here...
      Could you give me an advice?
      Thanks in advance
      Prova.pdf
      • DavidBoulderD
        DavidBoulder
        Not really great solution, but you can draw a line as a guide on a layer above your model views, and either move the box containing the model, or pan within the model until they match with the line.
        Then you can erase your guide line. Won't be perfect, but will be close.
        David Goldwasser
        OpenStudio Developer
        • G
          Gjenio
          Thanks, I hoped that there would have been another way to do that but it seems that's the only way to go trough the problem!
