    [TIPS 'ND TRICKS]: dragging textures to material editor
    6 Posts 3 Posters 1.8k Views 3 Watching
    • K
      kwistenbiebel
      Hi people,
      I am using Sketchup for more than 4 years now and still from time to time I stumble upon a feature I didn't know of.
      This one is a great one. A lot of you will already use it but I just discovered it today by accident.
      Here it goes:
      Instead of browsing a texture and digging into folders to change a material texture, 'drag and drop' your textures from explorer into the texture slot. Waaay more efficient.
      That's it.
      I hope some of you found this helpful.
      Regards,
      Kwistenbiebel
      • L
        lewiswadsworth
        Also works with styles (.style files) and the Styles Window.
        col sporcar si trova
        • K
          kwistenbiebel
          I see...
          what about dragging in another SU model?....must try that.
          • L
            lewiswadsworth
            Yes, you can drag and drop SU models into an open SU window and they will appear as components in the current model. I do this when reviewing students work on a projected screen...it is much faster to drag the submitted homework assignments into an empty SU model than it is to to go through a bunch of dialogs just to load the next assignment for review.
            There are a lot of drag-and-drop sort of things in SU, at least on Windows. For instance, you can drag importable image files like JPEGs and drop them right into your model. I have to assume it works the same on a Mac.
            (Note that it doesn't seem to work with other model formats.)
            • K
              kwistenbiebel
              Interesting.
              I find the drag-'nd-drop method extremely handy when working with a dual screen setup.
              SU on the left screen, explorer windows on the right screen.
              • R
                remus
                Cool tips guys, always nice to learn new stuff.
