    Custom shortcut cheatsheet
    7 Posts 7 Posters 8.8k Views 7 Watching
    • A
      alz
      Here're my shortcut cheatsheets I use for SketchUp. It ties into several different plugins/functions. (So native SketchUp does not support all of these shortcuts - if you don't have the plugin/function, some items won't work.)
      Does anyone else have custom cheatsheets?
      right-click and save or view image to see complete image
      http://img.photobucket.com/albums/v405/alz/SU_keyboard.png
      http://img.photobucket.com/albums/v405/alz/SU_keychart.png
      All images
      • R
        remus
        Damm, thats really organised. I dont think id ever be able to produce something like that- theres just no system to my shortcuts at all. I dont think id be able to list all my shortcuts ither, i seem to just rember them when i ned them πŸ˜›
        Good idea though, i imagine it will pay off in the end to have a half decent system for your shorcuts.
        p.s. you might want to use a slightly smaller image so that the pics fit the forum, i tink 700 across is the max size.
        • A
          alpmeadow
          Thanks for the cheatsheet. What plugins/functions are special use shortcuts/functions that are enabled for you?
          I use a timberframing ruby with its own shortcuts that are somewhat different. Below is a listing of the preferences for its functions. I want to minimise the potential conflicts with other rubies. Thanks for your help.
          alpmeadow
          0 0 0 F6 Edit/Item/Flip Along/Component's Red
          0 0 0 F7 Edit/Item/Flip Along/Component's Green
          0 0 0 F8 Edit/Item/Flip Along/Component's Blue
          0 0 0 F4 selectDimensionTool:
          0 0 0 F3 viewZoomExtents:
          0 0 0 F11 Edit/Item/TF Make Shop Drawings
          0 0 0 F9 Edit/Item/Text Position/Outside Start
          0 0 0 F10 Edit/Item/Text Position/Outside End
          0 0 0 N selectTextTool:
          0 0 0 A selectProtractorTool:
          0 0 0 V selectFieldOfViewTool:
          0 0 0 F5 Edit/Item/Rotate 90 around Z
          0 0 0 F2 viewFront
          • S
            spirp
            Alz, great cheat sheet! I wish I was patient enough to create something like that. This sparked an idea though, wouldn't it be possible to create a ruby that creates a snazzy cheat sheet like this?
            // Olle
            • J
              Jim
              // Olle
              If someone wants to provide a template file, inserting your personal shortcuts from SketchUp would be fairly easy to do.
              • JasonWDJ
                JasonWD
                I thought I would resurect this post because I was looking for a good template for an RGB keyboard.
                So I used my keyboard shortcuts in combination with the very good template above to make a Corsair RGB profile for SketchUp...
                https://dl.dropboxusercontent.com/u/773268/File 22-01-2016%2C 15 04 55.jpeg
                SketchUp, Thea Render, Vectorworks PC and Mac - Full LayOut workflow Concept>Production
                • S
                  samanathaebroadhurst
                  Here's another keyboard shortcuts site called SketchUp Shortcuts. I tend to use it because the URL is very easy to remember.
