    I need an OEM Plug in
    6 Posts 4 Posters 1.5k Views 4 Watching
      mkprofiles
      I am in the process of modeling up my company’s profiles and components and would like to get an OEM plug in made for these products. It would be similar to the Render Plus package but with things specific to our products. This includes length variable pricing, cost per square foot pricing, product configuration, and several other features. We will need licensing for as many as 50 seats for this package here in the USA. Global opportunities also exist.
      If you think you can help me please drop me a line. Serious inquires only as I will have corporate backing to do this and any offers to work with us will be closely scrutinized and will have to be approved by my management.
        Jim
        Hi Mk,
        I've moved your request to the Ruby Forum as you'll target your audience better here.
          Jim
          Not asking for details, but did you get a response on this?
          • Al HartA Offline
            Al Hart
            mkprofiles ,
            Render Plus RpReports is probably the best solution for you. Most of the customization required is already build into RpReports - the ability to define attributes, calculations, etc. But we can also create whatever custom capabilities are needed.
            I will contact you directly for more details.
            Al Hart
            IRender nXt from Render Plus
              mkprofiles
              I am going to bump this as I am still looking for help.
              • P Offline
                peweuk
                Not totally sure of everything you are after, but won't the facility of custom fields in Dynamic components introduced in V7 be of use.
                I am no coder, and have not studied all the possibilities in the formulas that can be used in the 'Custom' fields, but if I read your examples correctly, you should be able to add items based on calculations (eg length pricing).
                I had a similar requirement for adding custom attributes and found that the cost of the options available previously was prohibitive, but a breeze in V7 (except for the reporting - but that's the subject of another post http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15052)
