    Start with out profiles! How? Template dosen't work.
    28 Posts 12 Posters 3.9k Views 12 Watching
    • H Offline
      Hazza
      @sorgesu said:
      Here is an example of a template saved without updating the style. Take a look at how the style icon looks in the style browser and also try to add a scene.
      I downloaded and used your file as a template. I see the two arrows in a circle, I do not see the warning dialogue box when I add a scene.
      See all of my SketchUp models here.
        You'll only get the warning box if you've changed the style in some way from the previous scene. Or changed it away from the default settings before adding the first scene. Changing the style includes switching from Perspective to Parallel Projection of 2-point Perspective as well as Face Style and the settings you can make in the Styles browser.
        • H Offline
          Hazza
          No matter what I try it does not give me that warning. Can some one post a step by step guide?
            GO to Window>Preferences>General and make sure the bottom check box is ticked. It enables SU to warn you of changes to the Style.
            This is a registry setting and not part of the template.
              sorgesu
              Interesting, that warning is a default setting, I think. So it would have had to be turned off at some point.
              Susan Sorger
              • W Offline
                watkins
                Dear All,
                This thread has given me an idea for a new thread. I shall call it Templates for Newbies, and I will post the first one with some useful textures for mechanical parts.
                Regards,
                Bob
                • H Offline
                  Hazza
                  Ta da.... and now the penny drops as to why I do not get the warning. I just knew it had to be a tick box that stops annoying messages. It is a habit of mine to disable any warning messages when possible. I have been bitten once or twice instead of annoyed thousands.
                    Mind Hazza that if you use different styles in the same model, this is not an "annoying message" but a pretty useful dialog box where you can set different things.
                    • 2 / 2
