    Start with out profiles! How? Template dosen't work.
    28 Posts 12 Posters 4.0k Views 12 Watching
    • H
      Hazza
      Wooo hoooo I figured out how to create your own custom template without Bruce or that stupid ruler and to have profiles turned off. Heres how:
      1. Open a new file.
      2. Delete the ruler/Bruce.
      3. Turn off the profile.
      4. Change any other settings.
      5. Purge the unused ruler/Bryce.
      6. Purge the unused materials.
      7. Go "File -> Save as"
      8. Browse to your Template directory, by default it is "C:\Program Files\Google\Google SketchUp 6\Resources\en-US\Templates"
      9. Give it a custom name, mine is "8th inch no profile"
      10. Go to "Windows -> Preferences"
      11. On the left select "Templates"
      12. From the drop down, select your new template.
      [Edited: The purge steps were after the post by Dave R]
      See all of my SketchUp models here.
      • H
        Hazza
        Sure here it is.
        8th inches.skp
          Jim
          And then there's this; made just for this particular short-coming...
          Error 404 (Not Found)!!1
          (sketchuptips.blogspot.com)
            Isn't the thing about warning of changes to the style a registry thing?
            Hazza, it's just a personal preference but having Length Snapping on would drive me nuts. Since most of my SU work is drawing stuff that will actually be built and because I work closer than 1/16" in the shop, I set Precision higher.
              sorgesu
              Hazza, I looked at your template and the embeded style. The style was clearly updated with your changes at some point. If it had not been it would be clearly seen because the stye Icon would have had those arrows in a circle chasing one another. They weren't there so you did update and that is why you aren't getting the message.
              Here is an example of a template saved without updating the style. Take a look at how the style icon looks in the style browser and also try to add a scene.
              Anyway, you clearly did the deed, just forgot to mention it as a step.
              test.skp
              Susan Sorger
              Former Seller Hand Rendered Entourage
              Former Canadian Authorized Training Centre, SketchUp
              • H
                Hazza
                I downloaded and used your file as a template. I see the two arrows in a circle, I do not see the warning dialogue box when I add a scene.
                  You'll only get the warning box if you've changed the style in some way from the previous scene. Or changed it away from the default settings before adding the first scene. Changing the style includes switching from Perspective to Parallel Projection of 2-point Perspective as well as Face Style and the settings you can make in the Styles browser.
                  • H
                    Hazza
                    No matter what I try it does not give me that warning. Can some one post a step by step guide?
                      GO to Window>Preferences>General and make sure the bottom check box is ticked. It enables SU to warn you of changes to the Style.
                      This is a registry setting and not part of the template.
                        sorgesu
                        Interesting, that warning is a default setting, I think. So it would have had to be turned off at some point.
                        Susan Sorger
                        • W
                          watkins
                          Dear All,
                          This thread has given me an idea for a new thread. I shall call it Templates for Newbies, and I will post the first one with some useful textures for mechanical parts.
                          Regards,
                          Bob
                          • H
                            Hazza
                            Ta da.... and now the penny drops as to why I do not get the warning. I just knew it had to be a tick box that stops annoying messages. It is a habit of mine to disable any warning messages when possible. I have been bitten once or twice instead of annoyed thousands.
                            • GaieusG
                              Mind Hazza that if you use different styles in the same model, this is not an "annoying message" but a pretty useful dialog box where you can set different things.
                              • 2 / 2
