    Modeling question
    6 Posts 4 Posters 910 Views 4 Watching
    • D
      dionysg
      I was browsing through the net and found this picture.Tried using soapskin but the result was not even close.Any ideas from the pros on how can i model this.
      • I
        ilay7k
        mmm...thoughts, clipmaps(or image with alpha channels)...it's render
        then using FFD to splash sphere or cube with sub-subd. to get this form(or look at incredible buildings by fbartels...geometric-formula meshes)
        uv-mapping - Urgen's tricks from art-sketch...
        • R
          remus
          I reckon the method you use will really depend on how accurate you want the model. If accuracy sint too important, you could probably just model a skin and then apply a PNG texture with some transparency to get the gaps in the surface.
          If you want a more physically accurate model, i tihnk youd be much better off with a modelling program such as topmod: http://www-viz.tamu.edu/faculty/ergun/research/topology/
          I havent uset it myself, but i think you could probably produce some pretty good results, looking at other models that people have made.
          • J
            johnsenior1973
            http://sketchup.google.com/3dwarehouse/details?mid=62106ea4ab4e4e67dd319b887474e532
            I'll try and write up a quick way to do this.
            • D
              dionysg
              Its pretty close.Ill w8 for the tut
              • J
                johnsenior1973
                http://sketchup.google.com/3dwarehouse/details?mid=d0658dd8334c7c2da76655b2a48d2c2f
                It was doing my head in writing a tute. Hopefully you'll be able to work it out from that.
