    Taking the Mickey
    25 Posts 20 Posters 2.4k Views 20 Watching
    • soloS Offline
      solo
      http://img502.imageshack.us/img502/9459/mickeylinezv4.jpg
      http://img186.imageshack.us/img186/5518/mickey27op0.jpg
      http://www.solos-art.com
        remus
        i hope you haent been playign with subd and smooth again, i warned you about it πŸ˜›
        • P Offline
          pav_3j
          how, just how?
          don't you get bored of being this good?
          come on then, spill, what was the modelling time for that beauty.
          pav
          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
          • soloS Offline
            solo
            No beans to spill really, do you sketch or do any sculpturing?
            I model the same way I do other art works, the trick is to do it with the minimum poly's which sometimes I suck at.
            I try do most of my modeling with SU and thanks to our coders with plugins like Subsmooth, FFD, JPP, curve offset, weld, etc it is becoming possible. every now and again I do use Z-brush but that just means a zillion polys too many.
            The only advice I have is to play as much as possible, don't model simple stuff you know you can achieve, try difficult shapes and learn from your mistakes. Another thing is keep current as a week away from SU leads to forgoten techniques and fading fluency.
            Mickey took just over 3 hours from start to completed render.
            I have still so much to learn, there are many much better modelers out there that I take inspiration from.
            • F Offline
              fbartels
              Pete,
              Another amazing model!
              What a strange creature Mickey is. What size feet are those?
              Fred
                ScottPara
                Pete,
                Any way we can see a wireframe prior to sub-d?
                Scott
                Love the fact that some HATE my avatar.....
                • soloS Offline
                  solo
                  Scott,
                  I modeled it in components using the manipulated and resized ball method (as used in my organic modeling thread) for head, torso, hands and shoes, follow me for limbs, offset and JPP for trousers. I never used Subsmooth on this one.
                  • StinkieS Offline
                    Stinkie
                    Quite impressive, as always.
                    Have you ever considered teaching SU? I reckon you might be good at it.
                    • K Offline
                      kwistenbiebel
                      Gosh,
                      That's nice modeling.
                      I would never be able to do that.
                        Jon
                        Wow! That's incredible! 😲
                        I'm probably way out of line here, but...
                        would it be too much to ask for the model? πŸ€“
                        Jon
                        KT Team member
                        • soloS Offline
                          solo
                          Jon
                          PM your addy, I will send it your way (note I used high poly spheres so file size may be a tad high)
                            lapx
                            You can now retire. With this type of skill, it's time to teach to the masses πŸ˜„
                            You should seriouly consider writing a book on technique etc. then we can see you on cnbc's "The Big Idea".
                            Excellent work as usual Solo 😎
                              Jon
                              @solo said:
                              Jon
                              Thanks a lot! πŸ˜„ πŸ˜„
                              Jon
                              KT Team member
                                dylan
                                That is so good!
                                You obviously are a natural flair for art also. Its difficult enough to model, but probably just as hard to get the correct look.
                                Just over 3hrs, that is impressive. πŸ‘
                                http://dmdarchitecture.co.uk/
                                  Julius
                                  fantastic pete! i'm really impressed of what you can achieve using SU.
                                  • marked001M Offline
                                    marked001
                                    yeah, this is just really amazing pete..
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                    • W Offline
                                      Whaat
                                      Impressive modelling, solo!
                                      I am really curious to see you do some character modelling using Subsmooth. It seems like the Mickey model would have been a perfect candidate for using the plugin. Will we see some Subsmooth characters soon? πŸ’š
                                        lapx
                                        Someone who knows sketchyphysics needs to put Mickey's eye's in motion, I can see them rollingt at me πŸ˜„
                                        • W Offline
                                          werdj
                                          @solo said:
                                          ...with plugins like Subsmooth, FFD, JPP, curve offset, weld, etc...
                                          Can someone point out what FFD, JPP stand for, inlcude a link to videos of the tool in use?
                                          I have googled but don't want to be led in the wrong direction. What do those stand for, and what is their function? I have looked breifly at
                                          http://www.smustard.com
                                          and
                                          http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm
                                          Thank you.
                                          • ely862meE Offline
                                            ely862me
                                            u re unbeliveable
                                            Elisei (sketchupper)
                                            Come and See EliseiDesign
                                            • 1 / 2
