    Subsmooth object
    19 Posts 12 Posters 5.8k Views 12 Watching
    • K Offline
      kwistenbiebel
      Hi friends,
      The finished renderings of my first modeling steps using the 'subsmooth' plugin.
      Also used: 'joint push pull' and the 'FFD' plugin.
      Rendered in a studio setup using Fry Render.(curved background, 2 emitters )
      Regards,
      Kwistenbiebel
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/strange-object-smalla.jpg
      http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/strange-objects-n2-fry.jpg
      • soloS Offline
        solo
        Cool modeling.....
        Okay, I give up! what is it?
        a turkey leg contraption used for mashing potatoes?
        http://www.solos-art.com
        • marked001M Offline
          marked001
          nice...very cool 'thing'..haha.. need to check these ruby's out, for sure...
          http://www.revision21vis.com
          instagram: revi21on
            Buzzer1001
            "Useful object" huh? I don't want to go there!
            Kwisten - could you possibly post a screenshot/s of the SU model? I'm keen to see how you modelled it, i.e. how the tool works.
            Cheers
            • soloS Offline
              solo
              Buzzer I never saw that until you kinda mentioned it ... lol. 😮 💚
              • P Offline
                pav_3j
                that is really nice.
                i still have no idea what it is though.
                pav
                Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                • K Offline
                  kwistenbiebel
                  'Useful'...he he: semantics 😉
                  I must say my mind seems to be more Victorian than yours. 😄
                  Some screengrabs of the generated mesh :
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/mesh1a.jpg
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/mesh2a.jpg
                  A view on the modeling method:
                  As you can see, the 'proxy' consists of a couple of cilinders which are 'jointpushpulled', resulting in the ribs and the chicken tows...
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/proxya.jpg
                  A rendered view on the leg part:
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/strange-foota.jpg
                  I hope this clarified it a bit.
                    ScottPara
                    it must be a "modern" toilet brush" 😆
                    Scott
                    Love the fact that some HATE my avatar.....
                    • P Offline
                      pav_3j
                      that would be amazing to use during sex...
                      ...you could wedge it up against the door so no-one can get in.
                      he he
                      pav
                        tomislavm
                        It is nice and this is an very useful tool!
                        • boofredlayB Offline
                          boofredlay
                          I know what it is... it is the new model of this:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?p=14949#p14949
                          Nice work Kwist and thanks for the screen grabs too.
                          • K Offline
                            kwistenbiebel
                            He he 😄 Thanks.
                            After applying some deformations (FFD), the object becomes 'creature'.
                            Each FFD operation took more than 20 minutes to calculate 😲 ....It was a matter of not moving the mouse outside the viewport while the deformation process is busy, otherwise SU bugsplatted without exception (the famous "This process is not responsive" message in Windows).
                            Same goes for the subsmooth plugin. Doing a repetitive series of subdivisions gets you in bug splat land.
                            Well you know how SU handles lots of polies....
                            Rendered using Skindigo:
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/strangecreautureone1.jpg
                              dylan
                              Very nice Kwist and nicely rendered.
                              It's good to see the before and after.
                              http://dmdarchitecture.co.uk/
                              • W Offline
                                watkins
                                Why don't you see if you can model a cactus.
                                Cactus - Wikipedia
                                (en.wikipedia.org)
                                Regards,
                                Bob
                                  remus
                                  Kwist, couldnt you have used FFD on the proxy rather than the subsurface?
                                  • K Offline
                                    kwistenbiebel
                                    Thanks for the comments.
                                    @Remus,
                                    mmm...applying FFD to the proxy? That sounds like something I need to try.
                                      remus
                                      Yeah, just FFD the proxy. Thinking aobut it a bit more: you might need to subdivide the proxy first to get something that looks half decent, in which case youdonlyneed to use the smooth tool on it. Im sure youve already worked that out though...
                                      • P Offline
                                        princedragoncok
                                        Just bought subdivide and smooth 😄, so decided to pay tribute to Biebel's 'useful object'. Proxy greatly appreciated. Hopefully I'll be making some useful contributions of my own soon too. Rendered in podium 1.5. oh and how do I get rid of the attachment at the bottom btw??
                                        http://www.sketchucation.com/forums/scf/download/file.php?mode=view&id=9727&sid=d286fbad28e63059fe2d20dbbeb4bb9e
                                          remus
                                          Very green ans useful 😄
                                          to remove that attachment at the bottom, edit your post (btton in the top right of the post) then scroll down untill you get to the attachments bit, just under the main window. There should then be a button that says 'delete file'
                                          I look forward to more subsmoothed wonders!
