    Alignment of mirrored parts
    3 Posts 2 Posters 857 Views 2 Watching
    • J
      johnd
      sample misal2.skpI wrote earlier about problems aligning two mirrored parts. I finally figured out that it was useful to have both the default style and the single pixel styles available. This allows me to switch to single pixel when I am close to alignment... and then finish the job in the single pixel style.
      Nevertheless, I still end up out of line.
      Attached, I hope, is an image of a simplified "cardboard lips" form... two arcs coming back together... that are not quite lined up. If I am successful in attaching two files, I will send another successful version and the much more complex object I have been trying to complete.
      Thanks,
      John D.
      Maybe? is there a way of adjusting sensitivity at the last moment? In " Preferences" could I switch to some setting where any line within four pixels gets "joined?"
      sample 1.skp
      • G
        GreyHead
        Have you checked the replies to your earlier post?
        The same thing applies here - use the inference engine to create your half your shape, make it a component, copy and paste in place then scale the copy by -1.
        The last image is the two components exploded and the dividing lines deleted - you can't do this unless the parts are coplanar.
        Does this do what you want?
        Bob
        • J
          johnd
          The image I provided here is very simple. The one's I am really interested in are of French chairs. The Thonet rocker is a classic, but I was working on a simpler "cafe" chair. It has curved braces and other things that join immediately below the seat.
          So, somewhere in the process of making the parts, I got something out of line by a fraction of a degree.
          I tried: Looking at the whole thing from the front view in parallel projection.
          Creating a huge rectangular block that aligned with the center and "pushing" it through the contents I had already made.
          I then used "intersect with model to create edges. After erasing all of the excess, I mirrored the "half chair" and "moved" everything back together.
          I am getting better at this, but the parts are so close I would think they would snap together.
          Thanks,
          John D
