    New Plant Library
    17 Posts 4 Posters 8.0k Views 4 Watching
    • Al HartA
      Al Hart
      We have created a library of about 350 plants. These are created as "always face camera" alpha-transparent images. They work pretty well in SketchUp, however, unfortunately, alpha-transparent images do not cast shadows. (There was someone working on geometry to convert alpha-transparent images to complex faces, so you could place the image on the face and have it cast shadows properly. I'm not sure if that was ever completed.)
      The alpha-image plants have a very low poly-count (1 image per plant), so they do not clog up your SketchUp drawing.
      Here is a sample: (also available as a .SKP model below)
      Cholla Cactus
      (The black background is the transparent part of the plant. It will be transparent in SketchUp)
      Sample Plant is SKP file
      Here is a SketchUp drawing with a couple of the plant components:
      I am attempting to load this library to the 3D Warehouse, but I am waiting for help from SketchUp on how to perform a bulk upload. A few samples are uploaded already in this collection:
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      I have also placed the entire library in a zip file:
      ftp;//ftp.renderplus.com/_download/IRender/IRender%20Plants.zip
      (This is a 40 meg download)
      You can extract this zip file into your SketchUp Components folder and use the plants.
      Perhaps someone can try one of these and let me know what you think.
      Al Hart
      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
      IRender nXt from Render Plus
      • R
        remus
        CHeers al, im always on the lookout for new plants, and im sure these wil come in ahndy.
        Do they render well? (if at all, i imagine its quite dependant on the engine šŸ˜‰ )
        • Al HartA
          Al Hart
          @remus said:
          Do they render well? (if at all, i imagine its quite dependent on the engine šŸ˜‰ )
          They probably render well in any renderer. Especially those which cast shadows properly from alpha images.
          As it turns out, they automatically render as realistic, fractal, 3D plants using IRender Plus. (But they are of use for anyone, and should be quite useful as they are)
          Here is an example:
          3D Plants in IRender
          Al Hart
          • S
            sorgesu
            you can get a free ruby script from Smustard that will create a vector outline around your alpha masked image and create a surface so that it will cast a shadow:
            File Not Found
            (www.smustard.com)
            Susan Sorger
            • R
              remus
              Looks liek a very cool script susan, but although the script is free, the actual processing work is done on the smustard server and for this you have to pay. I suppose if you have a lot of images to do though, it would be worth it. Careful about the terms and conditions though (theres a paragraph at the bottom about it.)
              Edit: ignore that last bit, that was just my imagination. You can do whatever you want with the processed components.
              • S
                sorgesu
                oh weird. Sorry about that. I thought it was a pay script but when I went to find the link it said free, so I thought that they had madee it free.
                It isn't an outrageaous price. on sale at the moment for $1 per image.
                Susan Sorger
                • Al HartA
                  Al Hart
                  I'll take a look, since I'll only have to run it once per image to create the library.
                  On the other hand, if it only traces alpha around the outside, and doesn't pick up transparent holes, it won't work for many of the plants. Such as this one with lots of internal holes:
                  Note to SUC moderators: Is there a way to set the forum to show alpha parts of images in white rather than black?
                  Al Hart
                  • Al HartA
                    Al Hart
                    The SMustard script did the trick. It took about 5 minutes to process an image.
                    Here is a grouping of 5 plants as placed in SketchUp. (Note the shadows. The advantage of these polygon - non alpha plants is that they can casr shadows in SketchUp.)
                    SKP model
                    Here is the grouping rendered with IRender Plus. Note the 3D shadows, and the 3d, fractal effect of the rendering. Each plant is rendered differently. This is especially noticeable at the top of the plants on the left.
                    IRender rendering
                    Random, fractal, pants
                    Conclusion, the SMustard component works pretty well, and is better in SketchUp because of the shadows. The only other disadvantage it that the SMustard component is about twice as large (because of the complex polygon created to cast the shadows.)
                    Al Hart
                    • S
                      sorgesu
                      The script is wonderful.
                      While Rick was creating this script he worked with some of my entourage images and I helped him to test it out as he went. At a high poly count the script is perfection and causes a wonderful shaodow to be cast. At the lower resolutions it was cutting accross some of the edges and creating some less than optimal shapes. Because our self-imposed rule is to have in the neighbourhood of no more than 200 segments per tree ( more for flowers, fewer for people) we couldn't end up using the script. It really takes a human to decide how long to make the segments and where to create an angle in order to trade off optimally between shadow shape and poly count.
                      Susan Sorger
                      • Al HartA
                        Al Hart
                        I did wind up with 1,700 edges in this example, as opposed to 4 edges in the alpha-image version.
                        We are working on a separate project to create dual complexity components - with the full component in one layer and a simple alpha-image, (or even a simple rectangle) in another layer. This idea should work well for your plants, because the user could use the alpha-image while modeling, and switch to the HI-POLY layer (for shadows) only when ready for the final rendering in SketchUp.
                        Our tests have shown that this works well for components like plants with multiple instances. SketchUp remains very fast while the HI-POLY layer is turned off.
                        Al Hart
                        • S
                          sorgesu
                          Sounds like an interesting possibility. Look forward to seeing it completed.
                          Do you imagine that if someone place some 100 trees with as high a poly count as the one you just created it should still be workable?
                          Susan Sorger
                          • Al HartA
                            Al Hart
                            Our initial tests show that the geometry in the HI-POLY layer, which is turned off, does not slow SketchUp down at all until you turn the HI-POLY layer on.
                            I'll create a sample for you of the Monkey Puzzle plant so you can try it out.
                            Al Hart
                            • GaieusG
                              This is great, Al, thanks for sharing! The WareHouse solution also seems to be a nice idea (I saw you giving this hint to someone in another post of yours).
                              Also, many PR renderers can handle alpha masks as clipmaskas so if you use the images in them, there should be no problem with the shadows (though you might want to be careful with the sun location relative to the plants).
                              @al hart said:
                              ...Note to SUC moderators: Is there a way to set the forum to show alpha parts of images in white rather than black?
                              Sorry Al, I have also noticed this before and we cannot do anything with it. The forum software creates a thumbnail of the original image automatically and it does not contain alpha transparency. When you click on the image however (to enlarge it / see the original), the alpha mask comes through.
                              • Al HartA
                                Al Hart
                                This .SKP contains 256 instances of a single dual-res plant. Download it and try it out. Switch display modes by turning of the LO-RES layer and turning on the HI-RES layer.
                                (I meant to call these LO-POLY and HI-POLY)
                                In LO-POLY mode, it is usable - it takes about a second to redraw the screen, and the Orbit tool is usable.
                                In HI-POLY mode, it almost brings the machine to a halt - it takes about 20 seconds to re-render the screen. However, the user only needs to switch to HI-POLY mode just before saving a rendering.
                                We could create a function to switch to HI-POLY MODE, export the 2D image - and switch back to LO-POLY mode so the user would not need to try to do much in HI-POLY mode.
                                Note the shadows appear in HI-POLY mode.
                                Hi-res display - note the shadows
                                Model with 256 dual-res plants
                                Al Hart
                                • S
                                  sorgesu
                                  Wonderful!
                                  But oh my gosh you will give me so much work to do. Now I will have to convert all 7 of our volumes, all 5 of our mini-paks and various assorted singles into low and hi poly versions. Woe is me.
                                  Susan Sorger
                                  • Al HartA
                                    Al Hart
                                    We have a separate project to automatically create dual-poly components.
                                    It takes an existing component, places all of the existing geometry in the high-poly layer, then creates a new "always face camera", lo-poly layer and places the thumbnail of the component into it. Then the user can model with the, admittedly crude", lo-poly version and turn on high-poly when ready to render. (This was the project which started the thread about putting the existing geometry in a component into a group, and then adding new geometry as well)
                                    We are writing this to support "instancing" in our rendering program. This will render with the hi-poly layer without ever having to turn it on inside SketchUp.
                                    This routine, or something similar to it, may make your job easier.
                                    Al Hart
                                    • S
                                      sorgesu
                                      Al,
                                      That would be great. Our existing libraries, as I have said are outlined carefully and sparesly in a low poly fashion.
                                      Would your script work with the existing low poly outline together with the high poly version or would your script require that the low poly version is just the image file?
                                      I would really want to be able to offer both the low poly outlined version as well as the high poly.
                                      Perhaps 3 layers?
                                      Susan Sorger
