    [Plugin] Name Group on Creation
    49 Posts 20 Posters 32.4k Views 20 Watching
      Jim
      This simple script creates a Group from the selected geometry, then prompts for the group's name. Use the "Make Named Group" function from the Edit menu. Also has a context menu item.
      2010-Dec-07
      • Up to 20 Names are saved between SketchUp sessions. The names are sored ina file name Plugins/makeNamedGroups_names.txt, which can be edited using a plain-text editor - one name per line.
      This file is meant to replace the file named makeNamedGroup+.rb, if installed.
      Download
      makeNamedGroup.rb
      • StinkieS Offline
        Stinkie
        Thanks. Very handy.
          alz
          Nice - Thanks Jim! I've added it as my new group shortcut.
          • plot-parisP Offline
            plot-paris
            quite handy.
            but sometimes I dont want to name a group (for example if it is just temporary). I do know nothing about programming. but is it possible to write a ruby, that lets the cursor appear within the group's name in the outliner after creation instead of popping up a new window?
            that would be the perfect solution for me...
              Jim
              @plot-paris said:
              quite handy.
              Just tapping the Enter key will make the dialog go away and name the group "Group". There is no way to select the group in the outliner for editing. (At least from Ruby.)
              • JClementsJ Offline
                JClements
                Thanks Jim, I changed my shortcut for grouping to your script.
                Question: Is it possible to have the Input Box "remember" its last position? Sometimes the input boxes can coverup the area you are working on and I want to move them out of the way.
                  a4chitect
                  it should ideally prompt in the VCB only 😄
                    Jim
                    Yes, but only if I switch it to use a WebDialog. Which I will do a little later just for kicks.
                      Jim
                      I quite like this idea - no dialog at all. I'll try this too.
                      EDIT: Unfortunately, this can't be done. Anyone guess why?
                        RickW
                        Going strictly on (sometimes faulty) memory, I think VCB input is only available to tools.
                        RickW
                        www.smustard.com
                          Jim
                          True, and also any key shortcut you hit while typing the name will exit the Tool anyway.
                            a4chitect
                            sorry for not checking myself first... thanks for looking into it
                              AlexMozg
                              Jim, thank you for a wonderful idea.
                              I edited your script and added list of the before entered values for a substitution
                              and also checking for an empty selection.
                              Jim, once again thank you.
                              Jim, I regret because published this script here.
                              I think that it is not nice for my part.
                                j_forrester
                                Can this be used commercially?
                                  Jim
                                  I sent you a PM.
                                    bianhai
                                    Thanks!Jim! 👍
                                    • W Offline
                                      watkins
                                      Dear Jim,
                                      Could you possibly modify your script to include a toggle On/OFF icon so that the box can be made to automatically pop up when a group is created. As it stands, leaving the Entity Info box open on the screen is more convenient. The box automatically popping up would remind the user to name the group, making Outliner easier to use. The toggle OFF option would be useful for those not needing the detail.
                                      Kind regards,
                                      Bob
                                        Jim
                                        Thanks, I've included your modified version in the first post of this thread.
                                        • W Offline
                                          watkins
                                          Dear Jim,
                                          I note that when a named group is deleted it disappears from the list in Outliner, but not from the list in makeNamedGroup+.rb.
                                          Is there any way to update/purge the list when groups are deleted?
                                          Kind regards,
                                          Bob
                                            Jim
                                            Hi Bob,
                                            I'll have a look at it over the weekend, as well as your earlier message.
                                            • 1 / 3
