    [Plugin] Name Group on Creation
    49 Posts 20 Posters 38.4k Views 20 Watching
      a4chitect
      it should ideally prompt in the VCB only 😄
        Jim
        @jclements said:
        Thanks Jim, I changed my shortcut for grouping to your script.
        Question: Is it possible to have the Input Box "remember" its last position? Sometimes the input boxes can coverup the area you are working on and I want to move them out of the way.
        Yes, but only if I switch it to use a WebDialog. Which I will do a little later just for kicks.
          Jim
          I quite like this idea - no dialog at all. I'll try this too.
          EDIT: Unfortunately, this can't be done. Anyone guess why?
            RickW
            Going strictly on (sometimes faulty) memory, I think VCB input is only available to tools.
            RickW
            www.smustard.com
              Jim
              True, and also any key shortcut you hit while typing the name will exit the Tool anyway.
                a4chitect
                sorry for not checking myself first... thanks for looking into it
                  AlexMozg
                  Jim, thank you for a wonderful idea.
                  I edited your script and added list of the before entered values for a substitution
                  and also checking for an empty selection.
                  Jim, once again thank you.
                  Jim, I regret because published this script here.
                  I think that it is not nice for my part.
                    j_forrester
                    Can this be used commercially?
                      Jim
                      I sent you a PM.
                        bianhai
                        Thanks!Jim! 👍
                        • W Offline
                          watkins
                          Dear Jim,
                          Could you possibly modify your script to include a toggle On/OFF icon so that the box can be made to automatically pop up when a group is created. As it stands, leaving the Entity Info box open on the screen is more convenient. The box automatically popping up would remind the user to name the group, making Outliner easier to use. The toggle OFF option would be useful for those not needing the detail.
                          Kind regards,
                          Bob
                            Jim
                            Thanks, I've included your modified version in the first post of this thread.
                            • W Offline
                              watkins
                              Dear Jim,
                              I note that when a named group is deleted it disappears from the list in Outliner, but not from the list in makeNamedGroup+.rb.
                              Is there any way to update/purge the list when groups are deleted?
                              Kind regards,
                              Bob
                                Jim
                                Hi Bob,
                                I'll have a look at it over the weekend, as well as your earlier message.
                                • W Offline
                                  watkins
                                  Dear Jim,
                                  As always, many thanks.
                                  By the way, the polymer base is in manufacture, and so is the load spreader. I am currently working on the details of the drive unit.
                                  Regards,
                                  Bob
                                    Jim
                                    @watkins said:
                                    Dear Jim,
                                    Kind regards,
                                    Bob
                                    Isn't this how it works? The dialog pops-up if you use the Make Group option in the Plugins menu.
                                    • W Offline
                                      watkins
                                      Dear Jim,
                                      Yes, you are right. I missed the right-click context menu. Apologies for wasting your time.
                                      Thanks,
                                      Bob
                                        Jim
                                        Good news - I found a way to detect when a Group is created. This is cool because now I can pop-up a dialog when the built-in Make Group is used - so there's no need for a separate menu item at all. I'll update when I get through it.
                                        Also, the option can be turned on and off using the Extensions (in Preferences) dialog, or a Toolbar button. Enabled you get a Name: prompt, disabled you get the normal Make Group.
                                        • W Offline
                                          watkins
                                          Dear Jim,
                                          Excellent news! I do not know why this not a feature of native SU as one needs to name groups if one is to use Outliner effectively.
                                          Remember, weekends are also for relaxing.
                                          Kind regards,
                                          Bob
                                          • JClementsJ Offline
                                            JClements
                                            Hi Jim,
                                            I've been using the newer edition for a while now. One thing I wish could be done is have the option to cut and paste a name from the drop-down list into the entry box and then modify the name. Or, perhaps, there could be another box in which the drop-down selection is automatically pasted so it could then be modified?
                                            Finally, I believe you have to add a space to "clear" group's existing name, is that correct? Would a "remove name" in the drop-down list (at the top or bottom of it) be helpful?
                                            John
                                            • 1 / 3
