    Roof Art
    18 Posts 6 Posters 3.0k Views 6 Watching
      twharvey
      Hi All,
      I mostly make models of old buildings and I've thought for a while that roof details make a big difference in realism of the model. the trouble is that I almost always take photos from the ground, which gives a distorted image of the roof. Some of this distortion can be overcome by manipulating the photos in PhotoShop (or, in my case, PaintShopPro).
      My problem comes about with the tiles or slates on ridges and hips. Does anybody have ideas about how to overcome this problem; or maybe a web site with roof details that can be legally copied.
      Thanks,
      Tom
      Tom
      • W Offline
        watkins
        Dear Tom,
        I think this is a problem that many have had when modelling historic buildings. I have tried using Google to look for suitable images, but I'm not too sure about copyright. I imagine it is less of an issue when when images are used non-commercially.
        I came across this while doing a quick scan for Stonesfield slate roofs:
        http://www.tewkesbury.gov.uk/media/pdf/g/1/Slate_Roofing_.pdf
        and thought you might be interested.
        Regards,
        Bob
          twharvey
          Bob,
          Thanks, these are some good photos. Here's another one.
          http://www.maintainyourchurch.org.uk/Home/tabid/36/Default.aspx
          Tom
          Tom
          • W Offline
            watkins
            Dear Tom,
            An excellent link. Many thanks for that.
            Regards,
            Bob
            • dcauldwellD Offline
              dcauldwell
              Tom
              I don't know if this is what you are looking for. I modelled a section of roof (40deg) with a hip and hip tile. I insert this into my model and modify it insitu to suit.
              David
              roof_40 deg.skp
              Sketchup 2017
              (vray 2.00)
                twharvey
                David,
                Cheers. That's just what I have in mind. I'm going to try to build up a library of different types of roof detail, e.g. Welsh Slate, red tiles, etc.
                Thanks,
                Tom
                Tom
                • W Offline
                  watkins
                  Dear Tom,
                  Please find attached one side of a slate roof made up of individual slates.
                  I made the skippy by browsing Google for images of single slates, and then using Paint to crop and stretch the image so that it looked about right. I saved the image as .jpg and then used it as the texture for a model of single slate. The slate roof is not much bigger than the model size for a single slate, and so quite acceptable. The individual slate is a 500 x 300 by 6 mm thick.
                  To get a better and more realistic model I suggest you do the following. Go down to your local builders merchants with a digital camera and photograph individual slates in plan view. I'm sure they won't mind if you explain why you want the images. Of course, you could also say that you are taking the photos for the purpose of matching to those existing, obviating the need for an explanation. Use a large piece of white card under the slate to give a neutral background. I suggest that you photograph several slates to get a mix of textures and shades.
                  Hope this helps.
                  Bob
                  Slate roof.skp
                    remus
                    To expand on watkins' idea a bit, (although im not sure if it would work, its an untested idea) you could try using didiers component spray script to randomly place the tiles along a line, this would give you a more naturaul look than any array and would be a lot faser thna placing each on by hand.
                      twharvey
                      Hi Remus,
                      Out of curiosity, what's
                      Best,
                      Tom
                      Tom
                        remus
                        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6913
                        The PDF manual does a better job than i could of explaining what it does.
                          dylan
                          A slate roof is a regular array Remus, otherwise it would leak.
                          http://dmdarchitecture.co.uk/
                            remus
                            Indeed it is. What i was tryign to say was that if you had a selection of slate tile components that you wanted to use to tile a roof it would either take you a long time doing it by hand or you would likely introduce some sort of pattern if you tried to use SU array features.
                              twharvey
                              David,
                              Here's one that I did with a smaller file size.
                              Tom
                              Temp.skp
                              Tom
                                twharvey
                                David,
                                I've also been thinking about gutters. Since I make my models with GE in mind, I tend to see them from above or at least at an angle from a high view point. So, I've sometimes put the gutters on the same plane as the roof material itself. Sometimes this looks OK; other times it looks silly. I've attached a recent model of a church tower with the gutters incorporated in the roof plane. This one seems OK.
                                But in the real roof on this tower, there are mold and stains on the hips of the roof. This is one of those that I had in mind wwhen I posed the question in the first place.
                                I've been thinking about an excursion to Malvern to photograph different roofs from above: good hill in the town.
                                Tom
                                Tower.skp
                                Tom
                                  twharvey
                                  David,
                                  Thaks for the Texture site. This is wonderful and I can use a lot of the samples here.
                                  Tom
                                  Tom
                                    dcauldwell
                                    Tom
                                    Ah yes - 'infinity and beyond'. I see where you are coming from now.
                                    On the other hand a day out in Malvern would be very pleasant!
                                    My need is for photomatching the model, so the low level appearance of a roof is important to me, hence modelling the steps in the roof plane.
                                    David
                                    Sketchup 2017
                                    (vray 2.00)
                                      caddict
                                      Nice tower Tom.
                                      There was a discussion a while back about achieving realistic looking textures. The best results were got when people had actually modelled the detail of the texture and then applied a material to each part. Like in Bob's slate roof, the tiles themselves are 3d entities. And also David's roof to some extent. I really think this is the way to go if one has the time of course.
                                        dcauldwell
                                        Tom
                                        Thanks for the lower poly model, it will look good from higher viewpoints.
                                        Its horses for courses.
                                        1 Very close in - model individual tiles/slates
                                        2 Low angle (medium distance) - use modelled roof (ie mine)
                                        3 higher angle (medium distance to infinity (and beyond!)) - use material only
                                        This has got me re-thinking roofs, as you have now modelled the eaves boxing etc. why not take another step and also model the gutter. I keep adding gutters seperately and modelling them into this component will save time (I may also model the brackets while I'm at it!)
                                        David
                                        Sketchup 2017
                                        (vray 2.00)
