    Roof Art
    18 Posts 6 Posters 3.0k Views 6 Watching
      remus
      To expand on watkins' idea a bit, (although im not sure if it would work, its an untested idea) you could try using didiers component spray script to randomly place the tiles along a line, this would give you a more naturaul look than any array and would be a lot faser thna placing each on by hand.
        twharvey
        Hi Remus,
        Out of curiosity, what's
        Best,
        Tom
        Tom
          remus
          404 Not Found
          (www.sketchucation.com)
          The PDF manual does a better job than i could of explaining what it does.
            dylan
            A slate roof is a regular array Remus, otherwise it would leak.
            http://dmdarchitecture.co.uk/
              remus
              Indeed it is. What i was tryign to say was that if you had a selection of slate tile components that you wanted to use to tile a roof it would either take you a long time doing it by hand or you would likely introduce some sort of pattern if you tried to use SU array features.
                twharvey
                David,
                Here's one that I did with a smaller file size.
                Tom
                Temp.skp
                Tom
                  twharvey
                  David,
                  I've also been thinking about gutters. Since I make my models with GE in mind, I tend to see them from above or at least at an angle from a high view point. So, I've sometimes put the gutters on the same plane as the roof material itself. Sometimes this looks OK; other times it looks silly. I've attached a recent model of a church tower with the gutters incorporated in the roof plane. This one seems OK.
                  But in the real roof on this tower, there are mold and stains on the hips of the roof. This is one of those that I had in mind wwhen I posed the question in the first place.
                  I've been thinking about an excursion to Malvern to photograph different roofs from above: good hill in the town.
                  Tom
                  Tower.skp
                  Tom
                    twharvey
                    David,
                    Thaks for the Texture site. This is wonderful and I can use a lot of the samples here.
                    Tom
                    Tom
                    • dcauldwellD Offline
                      dcauldwell
                      Tom
                      Ah yes - 'infinity and beyond'. I see where you are coming from now.
                      On the other hand a day out in Malvern would be very pleasant!
                      My need is for photomatching the model, so the low level appearance of a roof is important to me, hence modelling the steps in the roof plane.
                      David
                      Sketchup 2017
                      (vray 2.00)
                        caddict
                        Nice tower Tom.
                        There was a discussion a while back about achieving realistic looking textures. The best results were got when people had actually modelled the detail of the texture and then applied a material to each part. Like in Bob's slate roof, the tiles themselves are 3d entities. And also David's roof to some extent. I really think this is the way to go if one has the time of course.
                          dcauldwell
                          Tom
                          Thanks for the lower poly model, it will look good from higher viewpoints.
                          Its horses for courses.
                          1 Very close in - model individual tiles/slates
                          2 Low angle (medium distance) - use modelled roof (ie mine)
                          3 higher angle (medium distance to infinity (and beyond!)) - use material only
                          This has got me re-thinking roofs, as you have now modelled the eaves boxing etc. why not take another step and also model the gutter. I keep adding gutters seperately and modelling them into this component will save time (I may also model the brackets while I'm at it!)
                          David
                          Sketchup 2017
                          (vray 2.00)
