    Turning off proxy
    extensions
    17 Posts 6 Posters 2.9k Views 6 Watching
      Jorgensen
      Just found out that the proxy can quite easy manuel be moved to a specific layer.
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • RayOchoaR Offline
        RayOchoa
        wHAT Do you mean by turning off proxy?
        CaR DeSiGnS bY mE
        http://ray-ochoa.com
          remus
          Well if yoi have some grouped geometry and you try to use subd and smoothon the group it will create a proxy and some smoothed geometry. Obviously for the final result you only want the subd'd geometry and not the proxy, but it can be useful to keep the proxy for manipulating the subd'd geometry later.
          • PixeroP Offline
            Pixero
            Would you mind telling the rest of us how to do it?
              remus
              Open the group (containing the proxy and subsurf), triple click the proxy, right click->entity info->layer.
              Thats how i do it, anyway.
                Jorgensen
                But, if one modify the proxy, then one have to move the proxy again....
                  remus
                  you can just turn the layer back on, no need to move any geometry.
                    Jorgensen
                    If you modify the Proxy, you have to move it to the other layer again, but it might not bee a big problem. I haven't actuealy not played around with this Ruby that mutch 😄
                      remus
                      Are you sure? i dont have to move it back to another layer when i edit it...
                      • RayOchoaR Offline
                        RayOchoa
                        how do you all the thing with the layers? i don't get all dat
                        CaR DeSiGnS bY mE
                          remus
                          Well to summarise layers in a paragraph:
                          Layers only control the visibility of geometry, nothing else. To create a new layer go window->layers then click the littly plus sign. To move things to a different layer, select the stuff you want to move, right click->entity info. And the golden rule of layers: only draw on layer 0, keep groups/components on other layers.
                          Thats all their is to it really.
                          • RayOchoaR Offline
                            RayOchoa
                            Thx alot remus
                            CaR DeSiGnS bY mE
                            • PixeroP Offline
                              Pixero
                              Thanks. Works great.
                              • david_hD Offline
                                david_h
                                I am still having trouble with this. . .I know how to select one or the other, but it seems that moving one group to another layer is no help. It still hides both the Subsurf and the proxy. Anyone else having this trouble?
                                • K Offline
                                  kwistenbiebel
                                  David,it works just like Remus described.(Thank you remus for that useful hint).
                                  Are you sure you didn't select the subsurface instead of the proxy?
                                  By the way, if needed, the subsurface itself can also very easily be hidden. Just open the 'outliner' panel and there you will see it as a part of a group. right click 'subsurface' and hide.
                                  • david_hD Offline
                                    david_h
                                    Thanks Biebel. I will pay more attention to that. I thought I was following the direction of the post, but . .. .alas. . ..
                                    Try try again.
                                    D
                                    • david_hD Offline
                                      david_h
                                      Try try again.
                                      D
                                      Okay .. .the .lights came on. I get it now. I was skipping a step. All together now. . .
                                      "DUH!" 😄
