    Turning off proxy
    extensions
    17 Posts 6 Posters 3.8k Views 6 Watching
    • PixeroP
      Pixero
      @jorgensen said:
      Just found out that the proxy can quite easy manuel be moved to a specific layer.
      Would you mind telling the rest of us how to do it?
        remus
        Open the group (containing the proxy and subsurf), triple click the proxy, right click->entity info->layer.
        Thats how i do it, anyway.
          Jorgensen
          But, if one modify the proxy, then one have to move the proxy again....
            remus
            you can just turn the layer back on, no need to move any geometry.
              Jorgensen
              If you modify the Proxy, you have to move it to the other layer again, but it might not bee a big problem. I haven't actuealy not played around with this Ruby that mutch 😄
                remus
                Are you sure? i dont have to move it back to another layer when i edit it...
                • RayOchoaR
                  RayOchoa
                  how do you all the thing with the layers? i don't get all dat
                  CaR DeSiGnS bY mE
                  http://ray-ochoa.com
                    remus
                    Well to summarise layers in a paragraph:
                    Layers only control the visibility of geometry, nothing else. To create a new layer go window->layers then click the littly plus sign. To move things to a different layer, select the stuff you want to move, right click->entity info. And the golden rule of layers: only draw on layer 0, keep groups/components on other layers.
                    Thats all their is to it really.
                    • RayOchoaR
                      RayOchoa
                      Thx alot remus
                      CaR DeSiGnS bY mE
                      • PixeroP
                        Pixero
                        Thanks. Works great.
                        • david_hD
                          david_h
                          I am still having trouble with this. . .I know how to select one or the other, but it seems that moving one group to another layer is no help. It still hides both the Subsurf and the proxy. Anyone else having this trouble?
                          • K
                            kwistenbiebel
                            David,it works just like Remus described.(Thank you remus for that useful hint).
                            Are you sure you didn't select the subsurface instead of the proxy?
                            By the way, if needed, the subsurface itself can also very easily be hidden. Just open the 'outliner' panel and there you will see it as a part of a group. right click 'subsurface' and hide.
                            • david_hD
                              david_h
                              Thanks Biebel. I will pay more attention to that. I thought I was following the direction of the post, but . .. .alas. . ..
                              Try try again.
                              D
                              • david_hD
                                david_h
                                Try try again.
                                D
                                Okay .. .the .lights came on. I get it now. I was skipping a step. All together now. . .
                                "DUH!" 😄
