    Tiny little things
    13 Posts 7 Posters 2.3k Views 7 Watching
      remus
      This seems rather too insignificant to have a whole topic devoted to it, so i welcome people to come forward and suggest their own small improvements. Just small things, mind.
      My nomination is to have SU infer a cube when your push pulling.
        Jim
        Remus, go write your paper.
        • boofredlayB Offline
          boofredlay
          Symptom of an all nighter πŸ˜„
          • plot-parisP Offline
            plot-paris
            my definite favourit for SketchUp 7 is, that bounding boxes of groups and components align to newly defined coordinate axes.
            because, if you allign your axes to a different angle, the bounding boxes of new groups/components still follow the original axes. thats why I rather change the sun direction than position the model to its correct compass orientation... 😞
            • I Offline
              igor
              i second remus' movement: SU sould infer a cube when push/pulling.
              even though its not small, i would like to have an option to make objects solid, like filled with stuff, not made out of infinitly thin faces. that way, when i get my hands on a 3-D printer, i dont have to export to a solids modeler.
              The genius switch has no "off" position
              Intelegence is natrual, it takes real effort to be ignorant
                remus
                I finished days ago james...ive just been relaxing for the weekend, and trying to think of cool things to do in SU of course.
                  And what did you get for the paper? Unless it is the best mark, I'll ban you till the end of the semester! πŸ˜„
                  BTW - I might be very tired )travelling all day and still up at 2 am) but I don't get what you mean by inferencing a cube.
                  • I Offline
                    igor
                    gaieus, what remus means is this: when you push/pull a perfect square, it sould infer when it is a perfect cube. like when you are using the rectange tool, it will infer a "golden section" or "square". see what we mean?
                    i cant wait to get my greedy little hands on a 3-D printer!!!...
                      Ah, I see. Makes sense. The cube is somewhat easy to create however with either entering precise values to the VCB or inferencing with other geometry but indeed I have missed the golden section inference quite a lot of times and the workaround for that is rather cumbersome.
                      Thanks for clarifying it (still very tired).
                      • StinkieS Offline
                        Stinkie
                        Hopes this makes sense: the ability to select faces along an axis using the arrow keys.
                        • I Offline
                          igor
                          oh, i see! like you use one of the axis inference keys (ie: up/down for blue axis) and it selects all the faces parallel to that axis. right? i never thought of that, thats a great idea. good thinking, stinky.
                          • StinkieS Offline
                            Stinkie
                            Thanks, Ygor. πŸ’š
                            • StinkieS Offline
                              Stinkie
                              This would be nice too: faster exploding. Probably been mentioned a couple of times before. πŸ˜’
