    🚹 Skimp | 25% Off until March 30 Buy Now
    Keyboard toggle for styles menus
    10 Posts 6 Posters 988 Views 6 Watching
    • david_hD Offline
      david_h
      can someone help me with a keyboard shortcut that would toggle between line styles "all the Same" and "Color by Axis". I am not sure where that is found in the command menu to define a SC to it.
      Thx in advance.
      David
        Jim
        Hi Dave,
        If you want, I will write up a script that will toggle between the options. Then you can assign a shortcut to it.
        • utilerU Offline
          utiler
          I'd be interested in this also, thanks for your offer to write small script, Jim!!
          Just Curious...
          • P Offline
            pmiller
            No need for a script -- look at your shortcuts menu under "view/rendering/edge/all the same"
            and "view/rendering/edge/by axis" then set up your shortcut key.
              Jim
              You are correct. I was thinking he wanted to toggle between Color By Axis and Color by Material.
              • utilerU Offline
                utiler
                cool, cheers.......
                Just Curious...
                • I Offline
                  iam_doss
                  Hi, I can see these items in Shortcuts but I can't see "Rendering" options under "View" in SketchUp. Missing something? Thank you
                  %(#000080)[Ignacio ArrĂșe
                  Arquitecto
                  OpenCartis, S.L.]
                    In Version 6 the edge styles you're looking for are under Window>Styles>Edit although the shortcuts are still assigned as if these things are under the View Menu.
                    • I Offline
                      iam_doss
                      Bizarre. Thanks, I am missing nothing 😄
                      Arquitecto
                      OpenCartis, S.L.]
                      • david_hD Offline
                        david_h
                        Thanks. . .I appreciate it. I knew it was inthere, I just couldn't find it.
