    Curved Ramp??
    7 Posts 5 Posters 6.6k Views 5 Watching
    • W
      wyteshooze
      Hi, im new to the forum.
      Dont know if this should be in the noob section, but just wanted to ask the pros, how on earth do I make a curved ramp? Basically ive want to make a curved ramp that goes up a cylinder, and i have no idea how it can be done?! would be great to find out!
      Cheers!
      • F
        fbartels
        Hi wyteshooze,
        Take a look at TaffGoch's tutorial models in the 3D warehouse. Marvelous stuff! πŸ‘
        http://sketchup.google.com/3dwarehouse/search?uq=09481412969015485894&scoring=d
        Fred
        • R
          remus
          This the sort of thing you want?
          http://farm4.static.flickr.com/3021/2424776841_c43265d2b5.jpg
          If it is i'll do a qick description...
          • TaffGochT
            TaffGoch
            wyteshooze,
            Actually, I can provide a a more-encompassing 3D Warehouse URL than the one Fred graciously mentioned. In this collection, you'll find Help-Group-discussion models from many contributors. Several of the models are tutorials addressing spiral/helical construction methods, including ramps and stairs:
            http://sketchup.google.com/3dwarehouse/cldetails?mid=34d9da9dcbd66dc16aa25eeaaa5db894&num=50&scoring=d
            (white shoes?)
            Regards,
            Taff
            "Information is not knowledge." -- Albert Einstein
            • G
              gksl4
              Have a look at aitop
              http://archsymb.com/ruby/index.php?dir=&file=aitop.zip&AutoIndex2=4e6bf40b1011f7ae6cd0bb267c601c82
              Another script you can use is grow.rb from TIG http://www.crai.archi.fr/RubyLibraryDepot/Ruby/EM/Grow.rb
              Also there is a nice tutorial from Jean Lemire about this matter in the old Sketchup Forum
              http://groups.google.com/group/Sketchup-Pro/browse_thread/thread/db9bf06a78d985de/205c16f39fbcd5ed?lnk=gst&q=jean+lemire+ramp#205c16f39fbcd5ed
              Regards,
              George
              • W
                wyteshooze
                Thanks guys for replying!
                But the thing that remus drew is EXACTLY what i want. Would be awesome if u provided a quick description. meanwhile ill run thru the tuts that taff and others provided! thanks again!
                PS. yep, it is white shoes, but spelt differently.
                • R
                  remus
                  Ok, jsut to warn you, this is a pretty bad way of doing it, and im sure there must be far more elegant solutions to this. Also you'll need fred06's ruby, joint push/pull, which you can find here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=6708
                  Step 1: draw a circle and push/pull it in to a cylinder (i only used 12 segments to my circle to speed up the process, use more if you want a smoother ramp/cylinder)
                  http://farm4.static.flickr.com/3040/2427666689_00286a8651.jpg?v=0
                  Step 2: Turn on hidden geometry (view->hidden geometry)
                  http://farm3.static.flickr.com/2271/2428479614_3dd928ba04.jpg?v=0
                  Step 3: Using the line tool, draw a line to connect the hidden lines, also notice that ive stopped the spiral just short of the top of the cylinder.
                  http://farm4.static.flickr.com/3078/2427667087_d552812b10.jpg
                  Step 4: Select the spiral and move a copy up.
                  http://farm4.static.flickr.com/3154/2427667223_359db73038.jpg
                  Step 5: Using the line tool, close all the faces by drawing a line between the upper and lower spiral, following along the hidden line (note ive turned of hidden geometry for clarity)
                  http://farm4.static.flickr.com/3044/2428480026_8bcf616f05.jpg
                  Step 6: Soften all the lines you just drew, this will effectively turn it in to one big face.
                  http://farm3.static.flickr.com/2362/2427667445_e5900f7f0f.jpg
                  Step 7: select the face and use fred06's joint push/pull ruby to push/pull the ramp out.
                  http://farm3.static.flickr.com/2313/2428480250_967c359cd3.jpg
