    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Location window disappeared
    4 Posts 2 Posters 951 Views 2 Watching
    • plot-parisP Offline
      plot-paris
      Help!!! my location tab in the Model Info Window has disappeared! ๐Ÿ˜ฎ
      I just wanted to specify the right location for my model to do some shadow testings with the survey buildings. but the tab of the location is not there anymore. it should be directly below "File" and above "Statistics" in the Model Info Window.
      did I schange something? is there a possibility to get it back?
        In Windows, the Location tab is only a Pro feature. Now if you have Pro and also problems with this, see if the 3D exporters still exist. Maybe your SU somehow get corrupted and degraded to the free version? ๐Ÿ˜ฒ
          plot-paris
          thanks a lot Gaieus, that explanes everything.
          in my office we have only a specific number of (serverbased) pro licenses. if all of them are in use, you automatically log in with a degraded license.
          so I dont have to worry about reinstalling SketchUp. and everything will be fine on monday (just have to come early to get one of the pro licenses ๐Ÿ˜‰ )
            Also, as a quick workaround, you can take a GE snapshot (you can toggle it off any time) and that will set your location in SU. Even "more also", Jim has created a plugin that will allow you to set the location on the free version of SU. Also he has a Sun tool and a Map Sun plugin for shadow studies.
            Finally, have you tried the new version of GE for shadow studies? Have a look at this thread (and the link in the first post). It seems to be really cool!
            And well, as it turned out that it's not a "bug", I'm moving the topic to the main forum now if you don't mind.
