    Simplify Tool
    10 Posts 8 Posters 18.8k Views 8 Watching
    • plot-parisP Offline
      plot-paris
      I am currently sitting on a model (that someone else has done πŸ˜‰ ) and looking for non continuous lines. after cleaning up a model I always feel better. however, why should one do tedious work, if SketchUp could it do for you in just a second?
      it would be really handy, if you could right klick on selected geometry and choose a "simplify" command, rather like "soften/smooth edges", to ged rid of all unnecessary edge.
      here you should be able to check a mark on "simplify edges" as well as "delete unnecessary lines"
      I think that could be another additional tool to make SketchUp even more powerful.
        remus
        There are quite a few CAD miport clean up scripts available here: http://www.smustard.com/scripts/
        Not sure i there are any that do what you want though, perhaps make a ruby request?
        • JClementsJ Offline
          JClements
          I agree, Plot.
          There are scripts that can do things like this, but to me it seems it should be incorporated into the basic code ... just like purging layers, components, and materials are.
            alz
            Don't progs like Max and Maya do this?
            I agree, SketchUp should have a basic "reduce polys/edges/lines, based on angle"
            In the above example, set the angle to 0 (zero) and any superfluous items will get nuked.
              a4chitect
              this part is taken (after a little modification) directly from the script Skin by Darrel Belvin so all credit is his (hope he doesn't mind me posting this)
              is taken (after a little modification) directly from the script [b]Skin[/b] by Darrel Belvin so all credit is his
              warning: please save your model prior to running this
              Script explanation:
              the loop goes through all selected geometry, check if the current entity is an edge, and if yes it erases this edge in 2 cases
              1. it is an edge belonging to 2 faces at the same time, their normals are parallel (faces are coplanar) and their front color is the same
              2. it is an edge which doesn't form any faces
              • StinkieS Offline
                Stinkie
                Thanks. This looks quite handy.
                  remus
                  Cheers, this is going to be another brilliant tool to add to the CAD cleanup collection.
                  • jujuJ Offline
                    juju
                    Shouldn't this be in a new thread in ruby section?
                      remus
                      Good point, heres the link: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=9429
                        sags
                        thank you very much for sharing.. πŸ‘
