    Missing lines
    2 Posts 2 Posters 729 Views 2 Watching
      cjlopez4
      Why do some lines not show up in SU when a model is transfered from Autocad?
      • plot-parisP Offline
        plot-paris
        sometimes that has something to do with layers. did you get a whole bunch of layers, when you imported?
        if yes, some of them may be hidden. the easiest way to get your model a bit more clearly arranged is to select them all (except layer0) and delete them. SketchUp will ask you, if you want to move the contents to the default layer (layer0). Confirm.
        perhaps that was the only problem...
