    Shell command
    6 Posts 5 Posters 712 Views 5 Watching
      dammerel
      Hi all
      You know what would be good in sketchup...A shell command
      Andrew
        Jim
        @dammerel said:
        Hi all
        Andrew
        Hi Andrew,
        To me, a shell command could mean several different things. Can you elaborate?
          dammerel
          to shell a solid by a thickness, like a bucket for example
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            The Push/Pull Tool, the Offset Tools and the Follow me Tools offer quite an array of possibilities to do what you describe.
            See attached SU file for ideas.
            Shell.skp
              If you want to put it that way, a "shell command" already exists in SU as a plugin (if I understand you well); Joint Push Pull by Fredo.
              • Alan FraserA Offline
                Alan Fraser
                Phew! I thought you meant DOS Shell for a while there. Yes, Joint P/P will do exactly what you want.
                JPP.skp
                3D Figures
