Shell command
Hi all
You know what would be good in sketchup...A shell commandAndrew
@dammerel said:
Hi all
Hi Andrew,
To me, a shell command could mean several different things. Can you elaborate?
to shell a solid by a thickness, like a bucket for example
Hi folks.
The Push/Pull Tool, the Offset Tools and the Follow me Tools offer quite an array of possibilities to do what you describe.
See attached SU file for ideas.
If you want to put it that way, a "shell command" already exists in SU as a plugin (if I understand you well); Joint Push Pull by Fredo.
Phew! I thought you meant DOS Shell for a while there. Yes, Joint P/P will do exactly what you want.
