    Update inserted files
    layout
    7 Posts 5 Posters 4.3k Views 5 Watching
      Jorgensen
      How does one update inserted files ?
      I have tried almost everything. Save the SKP drawing, in layout, selected update nothing happens. It seems like Layout does'nt see that the files has been updated 😞
      Any help ?
      Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        remus
        Have you tried right clciking the model in layout and selecting 'open with SU'? if you do that instead of openign the file straight in SU it should updae the file in layout.
          Jorgensen
          Hi Remus
          Thanks for your reply.
          It seems to work better, but Layout still looses 'contact' to the Sketchup file 😞 The only way to solve this, is to rename the Sketchup file and then relink. 😞(
            bjanzen
            Click File-> Document SetUp and select References. Do you have "Check references when loading this Doc" checked? In SketchUp, you can have modified but unsaved Scenes (right click on the Scene tab and save it, and save the document) or modified but unsaved Styles (you'll see the circular arrows indicating an unsaved style), and these are also items of confusion for some folks.
            Barry
              Bert
              Jorgenson, I am actualy using a french evaluation copy of SU pro and I have seen the answer to your question in the go-2-school.com/podcasts no 18 and what you have to do is:
              • save your changes made in SU then
                -in Layout go to File/Document configuration
                -Select your file and click actualise
              I might not have the exact words because my version of SU is in french
              Salutations (Best regards) Bert
                Jorgensen
                @bert
                Hi, I know this function, but I'm told that the file is allready "uptodate" -so it won't reload 😞
                • jujuJ Offline
                  juju
                  I had this problem once as well. I ended up unlinking the file, linking it to another, unlinking again and linking back to the correct (updated) SU model file. That worked as the LO didn't want to update the file with the updated model file with the same name as the one used in LO. So I solved it "old school" style.
