    Photoreal animation straight from SU
    21 Posts 7 Posters 6.2k Views 7 Watching
    • plot-parisP
      plot-paris
      @julius said:
      1. NEW! Target: Path allows you to select a target path.[/u] <---so basically you pay the 7$ only for this.
      you are right. but unfortunately this is exactly what I need. πŸ˜„
      honestly. a camera-aim path gives you a great deal of control over the sequence. only difficulty is to properly synchronise the two paths to achieve the desired change of focus at the right time.
      after a lot of trial and error I found out, that you best create two cubic bezier curves (fredo6's bezier tool plugin) with exactly the same number of control points. thus you can exactly see which point of the camera-aim path is connected to a certain point on the camera path...
      flightpath2 askes you for a speed (like 14 m per second). a scene is created at every vertex of the camera path and the transition times are set individually to retain the desired speed.
      however, I find it more useful, if all the scene transition times are the same - thus the number of vertexes on the path defines the speed (many vertexes, slow speed; few vertexes, high speed). unfortunately you need another script for resetting all the transition times back to default. you can get this script along with flightpath2 with the "presentation bundle2" for 16$
      it is a bit unnecessary, if you are comfortable enough with the free versions. but you definitely have total control over your animation.
      • 2 / 2
