    Sandbox problems.
    14 Posts 4 Posters 2.9k Views 4 Watching
    • david_hD Offline
      david_h
      On my home license of SU I have lost my Sandbox tools. I get the "file Error Loading. . .sandbox.rb etc etc" at start up. I have put all of the files and tools and folders in the proper folders, etc, because I am replicating the folder on my version here at the office, but to no avail. Sandbox tools does not show up in the Extensions folder of the Prefs dialogue eitherAny ideas? Is there a script or file I need to look for that helps enable sandbox? I have installed and reinstalled SU6 as well.
      thx,
      David_H
      • Alan FraserA Offline
        Alan Fraser
        Certain Google rubies, such as langhandler.rb are known to cause this if they are present in the Plugins folder (as they used to be in V5...they are now in Tools)
        3D Figures
          Yeah, when I upgraded from v5 and was stupid enough to simply copy all my Plugin folder to the new version, I got the same error messages until I got rid of langhandler.rb. That must be the culprit as Alan says.
          • david_hD Offline
            david_h
            Thank you my SU amigos. I will look at that.
            D
            • david_hD Offline
              david_h
              Still having the problems. Langhandler is in Tools, not plugins. I htink that is where it is supposed to by, cuz when I disable it, Nothing works. this is the error message I am getting.
              Error Loading File SandboxTools.rb
              wrong number of arguments(2 for 1)Error Loading File sandboxtools.rb
              • david_hD Offline
                david_h
                this is where I have my Sandbox folders on my OFfice version. IT works fine.
                Sandbox Folder : C:\Program Files@Last Software\sketchup 6\Tools
                Sandboxtools.rb C:\Program Files@Last Software\sketchup 6\Tools
                sandbox.strings C:\Program Files@Last Software\sketchup 6\Resources\en-US
                sandboxdefaults.ini C:\Program Files@Last Software\sketchup 6\Resources\en-US
                sandboxmenus.rb C:\Program Files@Last Software\sketchup 6\Tools\Sandbox
                • david_hD Offline
                  david_h
                  Helloooo! Anyone out there? Icould really use some help on this.
                  Thx,
                  David
                  • jujuJ Offline
                    juju
                    David_H, are you sure you have the installation directory path correct?
                    C:\Program Files**@Last Software\sketchup 6**\
                    Shouldn't that rather be "C:\Program Files*Google\Google SketchUp 6*" installation path?
                    • david_hD Offline
                      david_h
                      Well, I like to install SU to the old @Last directory. It's kinda my way of being anti-google. But the pathing to all of the Subfolders and such is correct. Maybe I need to rethink this. But I think I have that covered. Thanks for the thought tho'.
                      D
                      πŸ˜„
                      • david_hD Offline
                        david_h
                        you're probably right tho. I should reinstall. . .and Just load it to Google/google etc. Bite the bullet as it were. Then just copy all of the comps and plugins over.
                        😒 πŸ˜’
                        • jujuJ Offline
                          juju
                          There are some scripts from SU5 that have moved out of the plugins folder to elsewhere (these are default things that gets installed when you install SU6) so don't fret about that too much.
                          Be sure to copy ruby scripts over one at a time and check workability (i.e. load SU6).
                          Let us know how it went.
                          • david_hD Offline
                            david_h
                            SUCCESS!!! Thanks for the help! 😍
                            • jujuJ Offline
                              juju
                              Good to know, thanks for reporting back.
                              • david_hD Offline
                                david_h
                                Well. . .It's happening again. Anyone know why I am getting this error message on startup?Sandbox Problems.JPG
                                help!!!
